Re: Axis Camera Testing help
We seem to be double threading it here, but the error probably has nothing to do with the account authentication. That gives a pretty specific error message.
There are two TCP sessions being set up for the cRIO usage, one to the camera's server, and the other to the dashboard PC. Not having tried those VIs on the PC, it sounds like the camera session succeeds, but the dashboard is failing for some reason. It sounds like once the errors are done things work, correct? Greg McKaskle |
| Axis camera without the cRIO | CrazyCarl461 | NI LabVIEW | 12 | 17-01-2009 10:53 |
| axis camera - problem | s0crates | FRC Control System | 11 | 16-12-2008 09:34 |
| Camera Help (New to Camera Programming) | Idaman323 | Programming | 6 | 14-01-2006 03:56 |
| How do i connect the camera for testing? | naor52 | Programming | 1 | 12-01-2006 01:11 |
| Help testing RoboEmu 1.10 | rbayer | Programming | 26 | 27-01-2003 06:50 |
