Go to Post This is an open forum and it is a privilege to post here, if you don't agree with the rules then just don't post here. - dez250 [more]
Unread 20-12-2008, 11:55
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Help with the gaming bridge!!
No, you have to clip the wires of the wallwart. Cut them as close to the wallwart as possible, then strip both leads.
Alternatively, you can buy a matching barrel connector, and save the wallwart?
Unread 20-12-2008, 13:25
Felix has it.
We used a spare connector cut off some other old transformer (double check the wiring polarity).
What to do with the wall-wart is documented in manual section 3.2.6 "How do I build a cable for passing 12V power to the WiFi adapter?"
Unread 28-12-2008, 23:12
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
I am pretty sure the (+) has a dashed white stripes painted along the wire
edit:worked in ours
Unread 29-12-2008, 08:56
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
If you aren't sure of the polarity, get your Ohm meter out. The center of the plug is always positive and the outside is always negative. Put the meter on one wire and the outside of the plug. If the meter doesn't read zero, switch wires.
Unread 30-12-2008, 12:24
There is another thread on this subject. Radio Shack has the connector. Add some wire, check for polarity and install.
Unread 30-12-2008, 12:46
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Not Always!
If the device has this diagram on it then yes it it center positive:
If the Diagram is:
Then the center is negative and the outer shell is positive.
It is always a good idea to check with a continuity or an ohm meter to verify you have wired the connector correctly.
...Forest
Unread 30-12-2008, 13:04
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Why would you want to cut it as close to the wallwart as possible?
we cut ours about 6 inches away so in case at a later time we have wire to hook it back up again!
Unread 30-12-2008, 13:56
Racer26 Racer26 is offline
I'm with McGurky on this one... we cut ours off the wallwart, but we left a few inches of wire attached to the wallwart in case we wanted to put it back together for some reason. Its not like the cables aren't already 6 or 7 feet long, which is generally speaking, way more than enough for an FRC bot.
Unread 30-12-2008, 14:05
Good point.
When I wrote "cut the wire off close to the Wall-Wart", I did not mean "at the Wall-Wart". The wording is unclear. How about "cut the wire a few inches from the Wall-Wart"?
Unread 30-12-2008, 14:12
That is a much superior wording, IMO, as people generally take things to an extreme unless its spoonfed to them exactly what you meant. Now, I can't see any good reason we would WANT to hook it back up to a wall wart, but the point remains.
Unread 31-12-2008, 15:50
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
You can just buy a connector at radio shack. Try not to cannibalize the "wall wart" (I call them transformers), and instead just buy the stupid connectors somewhere. I don't know why anyone would ruin the transformer when the connectors are available everywhere.
here is one type available at Radio Shack or any retail electronics store. They have different sizes too.
http://www.radioshack.com/product/in...ductId=2102487
POLL: Gaming at the Regional Venue Taylor Chit-Chat 13 16-02-2007 11:32
Gaming to help vision! Heretic121 Chit-Chat 3 07-02-2007 19:02
Help with assignment please (Online Gaming Survey) Xidewinde Chit-Chat 15 25-10-2006 21:44
BRIDGE HELP, ASAP! archiver 2001 0 24-06-2002 01:03
