Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 21-12-2008, 11:37
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: 80/20 chassis
Drawing up the whole whole robot in advance is good advice for teams on a extreme budget. However, what we like about 80/20 is it's flexibility to change your mind. You can bolt things together, get a better idea, and change it quickly without cutting out and splicing welded pieces. It's fabulous for prototyping.
To do that you need enough material on hand to play around. 80/20 1" extrusion costs only $.23 an inch list price. The FIRST team price, if you can find a distributor who will do that for you, can be 35% or more off of that. The expense generally comes from all the special inserts, bolts, brackets, etc.
I'm not sure the exact numbers but I think the cost to 80/20 distributors for material destined for a FIRST team is 45% off of list. They then may add a bit for their handling of your order.
Chassis Torboticsmember General Forum 2 30-01-2008 16:30
autocad chassis kDude CAD 7 16-01-2008 10:07
Chassis Materials neoshaakti Technical Discussion 30 12-11-2007 21:08
Chassis? jakey Kit & Additional Hardware 1 09-01-2006 15:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
