Go to Post Please search before you post (it's fun and free!) - Billfred [more]
Unread 21-12-2008, 15:34
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Driver Station Help..
We are having some trouble programing the 09' Driver Station. We power it on and let it go through it's boot up. Then it come's up with..
Team Number : 0000
and etc. (I believe that is the default)
The first step in the Directions is to hold the "down" button for more than 5 seconds, and a "Set Team Number" screen should appear, We have done this many times but have never gotten that "Set Team Number" screen. Another question is what does it have to be connected to, like through Ethernet and etc.
Stumped on Stage one Thanks, Eddie 1708.
Unread 21-12-2008, 15:35
Billfred's Avatar
Billfred Billfred is offline
Re: Driver Station Help..
Team Number : 0000
Have you updated the firmware on the DS? Does it still read **OTB** at the bottom of the screen? If so, you're not quite at the point of setting team number yet.
Unread 21-12-2008, 16:11
Eddie
AKA: Eddie
Team Role: Driver
Actually, No we have not updated the Firmware on the DS, Could that be our problem, I don't remember any -OTB- I'll have to wait until school on Monday and let you know, Thank's for the Help
Unread 21-12-2008, 17:08
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Yes, you HAVE to update the DS before you can set the team number. This is clearly stated in the documentation.
(If you are planning to run the benchtop tests, do them before updating the DS firmware.)
Unread 21-12-2008, 18:00
Eddie
AKA: Eddie
Team Role: Driver
We are trying to run some Bench top test's, So your saying don't worry about the Team number when we are just doing some bench top's..?
Unread 21-12-2008, 18:22
Correct. I was able to run the benchtop tests without setting the team number. You only need to worry about setting team numbers after updating the firmware.
I would have to disagree here. I was very carefully reading all the documentation, and I didn't find that information until I hit Google in desperation. It would be better if they told us that we needed updated firmware at the beginning of the section where it talks about changing the team number.
Unread 22-12-2008, 15:05
Eddie
AKA: Eddie
Team Role: Driver
Our DS Still reads OTB, So we can run our Benchtop test's with no firmware updates..?
Thanks. Eddie Team 1708
Unread 22-12-2008, 15:09
Yes, you're supposed to run the benchtests before updating either the DS or the cRIO. In fact, if you upgrade either, you have to update both, and then the results aren't guaranteed to be the same as the expected results with the OTB firmware.
Unread 22-12-2008, 15:24
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
When following the directions step by step, you will hit the point where you are told to update the DS, cRIO and LabView. You will need to update LabView before the cRIO because the new image for the cRIO is included in the update file for LV. Once all three are updated, the bench-top results are quite a bit different than the first round of tests.
Again, as is stated in MANY threads here, follow the directions step by step.
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
Securing the Driver Station? Madison FRC Control System 16 16-12-2008 03:05
Mounting the Driver Station...? 1708xMr.Roboto FRC Control System 1 15-12-2008 12:34
2009 Driver Station Dimensions noxryan FRC Control System 5 27-11-2008 21:02
size of driver playing station 663.keith Technical Discussion 1 11-01-2005 13:23
