Go to Post If there isn't unity in your team, the outcome will never be good. - Arefin Bari [more]
  #106   Spotlight this post!
Unread 21-12-2008, 17:09
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
Re: surefire ways to break you robot
Find a minor problem and say, "I can fix that." It will turn into a major problem.
Alternately, say, "I can make that work better."
  #107   Spotlight this post!
Unread 21-12-2008, 17:13
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
I think that was the reason why the mentors wouldn't let me make some changes to the robot that would make it work better...
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
  #108   Spotlight this post!
Unread 21-12-2008, 17:38
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
Say, "we will get it after the next match",
Responding yes to "Is it fixed?"
Any time They call for the Pits to clear
  #109   Spotlight this post!
Unread 21-12-2008, 18:13
logicalyrandom logicalyrandom is offline
FRC #1787 (Flying Circuits)
Team Role: Electrical
logicalyrandom will become famous soon enough
-Cross wire the speed controllers. Fortunately we realized what we'd done before we turned the robot on.
-Forget to replace broken fuse.
-Forget to tighten zipties after replacing battery
These are all things we did with a test bot earlier this year.
If there is no possibility of shrapnel, you did it wrong.
  #110   Spotlight this post!
Unread 21-12-2008, 21:46
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
-when figuring where to put the battery, remember to drop the uncovered contacts directly on the metal frame. TWICE.
seriously though, kick it away with your RUBBER SOLED SHOE
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
  #111   Spotlight this post!
Unread 22-12-2008, 03:47
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Don't loktite the set screw on the CIM shaft.
Go full speed off any kind of ramp.
Not bother making an enable/disable dongle.
Use cheap limit switches to halt your lead screw's travel.
Overconfidence.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
  #112   Spotlight this post!
Unread 22-12-2008, 04:27
AdamHeard's Avatar
Lead Mentor
I'll second this, but a little more general.
Design, Wire and Maintain your robot so that shorts are not probable. Electrical layout should be the responsibility of both the mechanical/design teams and the electrical teams. Don't ever get into the us vs. them mentality. If you're mechanical and don't go out of your way to make electrical easier, you can't complain when it fails.
Your wire runs should be clean, organized, labeled and easy to differentiate between wires. If you have a short, or a motor not working somewhere, etc... you want to spend as little time possible finding what wire is hooked to what.
Electrical failures suck, they can cripple a mechanically perfect robot, and can be difficult to fix and diagnose.
Same goes for the relationship between mechanical/design and programmers. Make it as easy as possible for them... You are the SAME team afterall
  #113   Spotlight this post!
Unread 22-12-2008, 11:38
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Yep. Done that. Leaves a cool battle-scar on the frame though
Also, wiring through holes with sharp metal jagged edges.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
  #114   Spotlight this post!
Unread 22-12-2008, 23:34
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
- Drive the robot during a match where important school board of directors are watching.
- Deciding during the regional that after your robot can barely drive, you need to have some super-cool autonomous mode programmed before the next match.
- Assign a non-mechanical member a very critical task between regionals
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #115   Spotlight this post!
Unread 22-12-2008, 23:48
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
Find a way to make it to the final match.
This mostly pertains to VEX (first year doing FIRST):
- Have your battery removed by your alliance's robot (with the help of the opposing team's robot) during autonomous mode.
- Get "pinned" by another team from your own school and spark a controversial topic according to the "rulebook"... and lose.
- Be given a faulty frequency crystal and table during the match that shuts off your robot 30 seconds at a time... twice.
We've always never been able to place first cause of stupid things we can't control... curse anyone? haha
  #116   Spotlight this post!
Unread 23-12-2008, 00:55
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
-Have, a team member screw in the sprockets and then doing it so they are lose, then switching the same sprocket, and trying to get it in the sprocket hole again, but then stripping it, and then not being able to find a replacement in time.
-Tell a incompetent fool to press a trigger that controls the piston that goes up and down for your claws on the bot, and the fool goes trigger happy, leading to the snapping of the robot in two pieces.
-Rebuilding the gear box 18+ times, and then it still doesn't work
-having one wheel with a lot of drag then driving, and try to go full speed and the bot spins in a very quick circle with parts flying everywhere
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
  #117   Spotlight this post!
Unread 23-12-2008, 02:00
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Programing you motors for you lift to always to drive it down. (Nothing like the smell of a burning motor)
Finish programing while waiting to get on the field of you second match
Drilling a hole in your gearbox and not getting rid of the shavings
Use loktite to keep your gearboxes from coming apart then realizing you don't have a high enough gear ratio for mecanum wheels
  #118   Spotlight this post!
Unread 24-12-2008, 01:08
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Another way, is by not ziptieing down your encoder cords, or PWM cords, then running the robot in autonomous, then it spins and all you see is flying cords and pwm cord heads, you stop it and realize the all the cords got caught in the wheels.
Ben Kellogg
  #119   Spotlight this post!
Unread 24-12-2008, 03:53
surferacf's Avatar
surferacf surferacf is offline
Student Leader & Electrical Captain
AKA: Aaron F
FRC #3060 (The Fighting Tuna)
surferacf will become famous soon enough
While not technically part of the robot...
We were testing one day when our battery ran out. We pulled it out of the robot and asked one of the new kids to go back to our the room and get us a new one. He only saw one other battery, and it was half-charged.
I believe his thought process was "I can transfer the power from one half-charged battery into another half-charged battery to make a fully-charged battery! Hey, these connectors look like they can be plugged into each other..."
(Someone noticed just before he tried this and yelled. We all still have our limbs attached )
"Curiosity killed the cat, but for a while I was the suspect."
-Stephen Wright
  #120   Spotlight this post!
Unread 24-12-2008, 14:01
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
What? That sounds like a complete disaster!
Another way is building your robot completely, then in a practice match, run the autonomous code, that you have never tested (enough said) [our team did this, and our robot ran into the center divider, and the battery plug came undone, and we didn't know why our robot wasn't working until after the match.
Ben Kellogg
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
pic: strange ways you test stuff out? DarkFlame145 Robot Showcase 1 13-01-2008 15:10
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" Mr MOE General Forum 6 09-02-2007 08:40
What do you do when its time to take a break from building?? Leo 1529 Chit-Chat 23 13-02-2006 00:26
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 3 15-02-2005 11:38
