Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 24-06-2002, 00:01
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Another rules question
Posted by Patrick Dingle at 2/1/2001 10:05 PM EST
Other on team #639, Red B^2, from Ithaca High School and Cornell University.
Does anyone know if iron can be used (w/out purchasing from small parts)? Where is the line drawn between iron and steel, or is iron considered a type of steel? It's just more carbon content.
Thanks,
Patrick
#0047 (ChiefDelphi)
Re: Another rules question
Posted by Dave... at 2/1/2001 11:05 PM EST
Engineer on team #5, Robocards, from Melvindale, MI and AFL (Alcoa Fujikura Ltd).
In Reply to: Another rules question
Posted by Patrick Dingle on 2/1/2001 10:05 PM EST:
: Does anyone know if iron can be used (w/out purchasing from small parts)? Where is the line drawn between iron and steel, or is iron considered a type of steel? It's just more carbon content.
: Thanks,
: Patrick
Patrick,
You do not mention what type of iron/steel, but in either case, it must fall under the AHL. Sheets and plate up to 1/4" thick are listed as "steel", and angle is also listed as "steel." Most people and places refer to the angle as "angle iron", but you are correct in that steel is simply an alloy of iron with carbon and other trace elements. These elements make the iron stronger, and so I recommend using steel regardless over iron.
Only angle and plate up to 1/4" thick is allowed on the AHL, otherwise its back to SPI and their limited selection.
Dave...
[IMG] code is Off
Question on rules? dddriveman Motors 3 19-06-2003 22:50
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
A rules question Chubtoad Rules/Strategy 2 23-11-2002 22:42
Time for new rules! archiver 2001 11 24-06-2002 02:01
Rules Question archiver 2001 13 23-06-2002 23:58
