Go to Post It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated". - Mark McLeod [more]
Unread 12-22-2008, 02:18 PM
run the trap!!!
Team Role: Human Player
Re: pic: Arm joint idea
Originally Posted by artdutra04 View Post
Round tubes are easy to work with if the OD of the tube matches the ID of a square/rectangle tube. This gives you an easy flat surface to work with, face mount things to, press bearings or bushings into, etc.
Heat guns can be good persuaders to make the OD match the ID.
Thats pretty cool. But I don't see why you didn't just use square tubing the whole way.
Yes, square tubes aren't as torsionally stiff, but I'd think the lack of a joint would make up for it.
I have bad memories of team 852's fiberglass tube arm getting snaped off at the base at CalGames '07.
-Philip J. Fry
pic: Closeup of top joint and FP motor NK2007 Extra Discussion 10 02-10-2007 08:52 PM
locking a joint--suggestions? Joe G. Technical Discussion 2 01-12-2007 07:06 PM
pic: 121 shoulder joint motors Rob Robot Showcase 2 02-07-2005 09:16 AM
pic: End Joint of Sample Tetras Mark McLeod Extra Discussion 1 01-09-2005 05:05 PM
u joint needed gail Off-Season Events 1 11-16-2001 11:01 AM
