Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 20-12-2008, 15:15
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
New Control System Problems
Hey, I'm part of team of team 2429, this is our second year. Our mentor, leader, has yet to open the new control system box.
I have been coming on here, and have been noticing a lot of people posting forums on problems dealing with code, control, and other problems that they have been having with the new control system, and I was just wondering what are the main problems with installing it that our team should be aware of when we finally install the new control system?Also if you could be kind enough to also, post along with the problem, the solution to it, if you have found a solution to it. Thank you so much to all who reply.
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 20-12-2008, 15:47
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: New Control System Problems
We opened our box a week ago and had some minor problems. Our problems were the result of not following the directions in order.
My advice - follow step by step the instructions posted on the FIRST website.
http://www.usfirst.org/frccontrolsystem
Roger
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
Unread 20-12-2008, 15:57
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Roger
Yeah, always follow directions, I'll definitely make sure our team does that, are there any specifics anyone can give, because I see a lot of forums on decisions between C/C++ and LabView, and then forums that state problems with both, and other forums saying they are having problems with the camera, and other miscellaneous stuff. Is there any suggestions on code, and any other things, besides just following directions that can be given so our team can avoid as many problems as possible.
Ben Kellogg
Unread 21-12-2008, 23:00
ChrisH ChrisH is online now
Generally Useless
FRC #0330 (Beach 'Bots)
It will take several hours to get the new control system checked out and code updated so it is fit to use. Others have pointed out where instructions for this process can be found. Sometimes the instructions are unclear because the person doing them does not fully understand what they are being asked to do. (kind of like telling the color blind guy to "cut the green wire")
So before taking any step, be sure you understand what you are to do. You don't have to understand WHY, just HOW and WHAT.
I am in the process of setting up sessions that teams in the LA area can come to and be walked through the process by people who have done it twice, once with the Beta System and again with their early ship system. We will be doing sign-ups at Kickoff. More details later.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 21-12-2008, 23:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Read the instructions and then read them again before you do anything.
Remember the instructions will point you to places in other sections of the manual. It is very important to do only the section mentioned and then back to where you were referred from.
Unread 22-12-2008, 09:31
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
If you follow instructions, their shouldn't be any problems. The only part of the process we had trouble with was setting up the wireless. You Must follow the instructions to the letter to make it work. If you mess up at any point, you will have to start over. I think we had to go through the process 4 times before we did it right. Other than that, I think it should be okay.
Unread 22-12-2008, 10:00
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
For our team, one of the problems have been going through the setup process a little bit each day. We meet one hour a day and during that one hour, YOU DONT FINISH, so the next day you have to pick up where you left off and if the student who was working on step 6 isn't here the next day then we don't touch it until they return. We are paranoid about following the configuration steps. Anyhow, I kinda wish we would have just set a aside a 6 hour day to do the entire configuration and updates all at once. Instead it took two weeks. Other than that, just follow the directions and you'll be fine. Oh here's another weird quark.. 10.7.1.02 is not the same as 10.7.1.2 This maybe specific to our laptop but it took a while for us to figure out why labview wouldn't download code.
Programming in LabView is another story. Our C programmmers hate it, but I'm encouraging them to stick with it - It is important that they learn something new, it will serve them well in the end. Have the programmers watch the LVMastery videos (posted here on CD) and the videos at labviewzone.blip.tv those are really nice.
Unread 22-12-2008, 10:21
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
As the others have said, carefully read the instructions, and then read them again, and maybe one more time, then follow them through in a dry run. All the information is there, you just have to follow it.
Then make sure you have ChiefDelphi up on one of your computers when you need help ;>
If you have a chance to attend training like ChrisH is offering above, take it.
Unread 22-12-2008, 10:52
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
How much time should the entire setup take? I suspect we should do it in one session if possible.
Unread 22-12-2008, 11:02
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
If you install LabVIEW on a computer beforehand, the setup and the bench tests takes ~3-4 hours.
Here's an approximate breakdown, with plenty of slack:
Unboxing, wiring: 2h
Bench tests: 1h
Updating cRIO and DS (+setting team number) : .5h
Configuring the bridge, router, and camera: .5h
A lot of these can be done simultaneously if you know what you're doing (updating cRIO and DS at the same, configuring wireless at the same time), so you can save some time.
We made the mistake of not installing the software beforehand, though. On top of that, we had an old version of LabVIEW installed. The uninstalling took over an hour, and the reinstalling ran for a good two hours. We only had a three hour meeting on our first day with the cRIO, so we did everything beyond updating the DS on the next day since we did not have LabVIEW ready to update the cRIO. If we had installed LabVIEW beforehand, we could've finished the entire thing in our three hour meeting.
Unread 22-12-2008, 11:48
IndySam's Avatar
Key words are "if you know what you're doing ."
But if this is your first time through setup don't try to do this.
I don't care if you are the worlds greatest expert in computers, networking and the cRIO, shortcuts will cause you nothing but trouble.
"Shortcuts make long delays." Frodo Baggins
Unread 23-12-2008, 01:15
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay I have a second question, now. Since the kickoff is nearing, and our school is on winter break, and the lead mentor of the team decided that our only meeting over the 2 week break was going to be on Jan 3rd (kickoff). Should we wait to put the new control system on the new robot, or go ahead and install it on our old robot and test it?
Ben Kellogg
Unread 23-12-2008, 03:41
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
it doesn't matter. I recommend trying to get driving working as soon as possible, so yeah try to put it on an old robot if you have access to it.
there are NI labview tutorials, but they are rather boring. You can still find them at www.ni.com/first though.
But, i recommend these video's instead. I find them better.
http://www.lvmastery.com/files/FIRST..._Part1(2).html
(this one starts out a little boring, but has some useful info for part2,
and is still much less boring than the official NI video's)
http://www.lvmastery.com/files/First...c12_Part2.html
http://www.lvmastery.com/files/First...12_Part3b.html
Unread 23-12-2008, 16:29
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
As an alternative, you could mount everything on a piece of plywood with small motors to simulate your drive wheels and test it that way. You could continue to build the "Breadboard" with sensors and relays as your design for the new robot grows. That way, you aren't interfering with the build and most things should work when it is moved over to the bot. (You also don't need to disassemble your old bot.)
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
New Control System - Wireless Problems Ashwin FRC Control System 13 11-12-2008 10:38
New Control System koka230 FRC Control System 14 10-12-2008 02:07
new control system Sam2197 FRC Control System 2 22-11-2008 13:17
New control system? David55 Rumor Mill 2 29-12-2006 08:28
New Control System? smokescreen Rumor Mill 4 07-03-2002 15:48
