Go to Post Fame... Fortune... Bleh I'm inspired and thats all that matters to me - Noah Melamed [more]
Unread 23-12-2008, 07:38
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
what is the gyro sensitivity?
and how can i measure it?
I am using WPILIB library, so if you will write some code it would be more comfortable for understanding, thanks.
Unread 23-12-2008, 11:03
Re: what is the gyro sensitivity?
You should get it from the data sheet of the gyro you are using. It's the number of volts change in the sensor reading for every degree per second rotation rate.
ADXRS150 Gyro Yaw Sensor sensitivity? hinewwiner Technical Discussion 5 08-02-2008 09:20
controller sensitivity kDude Programming 5 06-02-2008 16:22
controller sensitivity kDude Programming 0 06-02-2008 15:42
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
joystick sensitivity Team 668 Programming 11 16-02-2005 18:45
