Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Unread 23-12-2008, 11:14
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
Joystick values (?)
what are the joystick values when I use GetX(), GetY() functions of the wpilib library?
Unread 23-12-2008, 11:26
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Joystick values (?)
GetY and GetX will return a float from 1 to -1 with 0 being in the center.
So, roughly 3/4 forward should return around .75 ish, in reality though the
number will probably be like .75124 if you use cout or printf.
Joystick axis values in new controller koreabell Programming 7 17-12-2008 11:39
Joystick Output Values? compwiz2008 Programming 5 17-01-2008 22:40
Mixing Joystick Values for mecanum wheels Leav Programming 10 15-01-2006 14:51
Servo Values DanDon Motors 8 14-02-2005 15:49
Color Values WesleyBalmer Programming 3 15-01-2005 22:26
