Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 23-12-2008, 12:36
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
Questions about ultrasonic
im using wpilib, are the pings automatically sent or i have to call this? please if you can, show me an example of code how to check if the robot is place by 2 inches from a wall.
Unread 23-12-2008, 13:17
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Questions about ultrasonic
Are you using LV or WR?
In C++, you have two options. You can repeatedly call the Ping() method, or you can set your sensor to automatic mode using SetAutomaticMode(true). Either way, after you've gotten at least one measurement back, use GetRangeInches or GetRangeMM to get the respective measurement.
Unread 30-12-2008, 22:59
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
And if you are using LabView, you can get the manual analog input and divide it by howmany volts the spec sheet says is per centimeter or meter.
Unread 02-01-2009, 20:35
DonRotolo's Avatar
Back to humble
FRC #0832
It also depends on which ultrasonic sensor you are using. The Maxbotix sensor can deliver the distance as a voltage of 0 to 2.55 volts, corresponding to 0 to 255 inches. In that case you would just read the analog value.
Unread 02-01-2009, 21:43
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
How linear are they and is there a myopic zone?
___________________
- Tennyson, Ulysses
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Questions about Championship RoboMadi Championship Event 9 17-03-2006 21:12
2 Questions about OI theCowboyKnight Control System 2 27-01-2005 11:38
questions about competition archiver 2000 2 23-06-2002 22:06
Questions about Battlecry Todd Derbyshire Off-Season Events 4 12-06-2002 23:16
