Go to Post Words mean what words mean. If your robot is sitting on the ball, then by definition it is not hanging from the bar. NO 50 point bonus. - dlavery [more]
Unread 25-11-2008, 11:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Pneumatic breakout question.
In the past when we wanted to use a two way valve we would wire it with diodes and just switch the spike from +12 to -12. I don't see where on the pneumatic bumper this is possible.
Any suggestions on using a two way valve withe the pneumatic breakout?
Unread 25-11-2008, 11:22
Re: Pneumatic breakout question.
The wiring demonstrated on the Data Connectivity Diagram indicates we must use two outputs for a double solenoid.
Or you can still use a Spike-only solution or a Spike and diode approach.
Eric will be along with the definitive answer momentarily
Unread 25-11-2008, 11:34
ATannahill ATannahill is offline
AKA: Alex Tannahill
Mark is right, you will use one of the eight outputs on the pneumatic breakout for each single solenoid or 2 for a double solenoid. Spikes can still be used if you want/need to. We did it on our beta robot to prove that it is possible and because we would need a bigger breakout if we were to run all pneumatics off of it.
- Arizona North
Unread 23-12-2008, 15:58
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
Is it correct to assume we need to "assemble" a 2 pin connector cable for the Solenoid Breakout to use with a double solenoid?
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
Unread 23-12-2008, 16:21
Yes, you do need a 2-pin connector cable to hook the solenoids to the Solenoid Breakout.
The 2-pin connector cables that came with the early control system, and will come in the KOP, can be cut in half to give you a pair of connectors.
Unread 23-12-2008, 17:10
Quick Reminder -
When using a double solenoid with the cRIO module, use two channels.
Pneumatic Ram Question Magnechu Pneumatics 14 23-01-2008 16:42
Pneumatic Tubing Question Ryan Dognaux Pneumatics 2 31-01-2004 20:23
Question on Pneumatic Cylinders RichardBCR Pneumatics 5 25-01-2004 22:46
LAST MINUTE Pneumatic Question archiver 2001 6 24-06-2002 01:11
