Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 23-12-2008, 19:03
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Joystick lag with DS being idle.
Hello,
I ran into an issue with the joystick having as much as a .5-3 second delay when the Driver Station was sitting idle for about 20 minutes to an hour with power applied. Once resetting the driver station only, the controls returned to normal.
This is being noted as a warning. I would not want someone being run over by their robot due to this delay. The commands sent from the joystick remain in the memory of the DS and will be eventually sent to the motors.
The cRio is only responding to the commands it receives, I can say that with some confidence because after the DS reset only, it was acting normal.
The firmware in the cRio and the DS are the latest upgrades provided by FIRST. There are no custom programs added yet.
Has this been noticed by any other teams?
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 23-12-2008, 19:07
Re: Joystick lag with DS being idle.
It's mentioned in section 3.1.8 of the manual and fixed with the latest cRIO image from LabVIEW update 2.
Unread 23-12-2008, 21:06
Smile Re: Joystick lag with DS being idle.
hello,
After installing Ver.2.0 there are no issues with the joystick lag. Monitoring the serial communications from the cRio reveals a check for dead packets and a subsequent resynch with the DS.
Problem resolved!
Maybe I spoke too soon. The serial port showed hundreds of "Packet Loss Error... lost 5" errors. The joystick delays returned, and no DS resynch occurred until the DS was reset by disconnecting the power.
Please be conscious of how long the DS has power applied before driving your robot. It may save you a match.
Jim E.
Unread 24-12-2008, 16:31
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Originally Posted by Jim E View Post
hello,
Did you reimage the cRIO after installing the update?
The fix was in the cRIO image I beleive.
Phil.
Phil Malone
http://www.GEARSinc.org
Getting the Camera out of Idle Eclipse Programming 2 13-02-2007 04:06
Help with joystick lightning_blast Programming 2 12-02-2006 22:25
Segways being used at CT airport by State Troopers. (with video) Elgin Clock Dean Kamen's Inventions 1 22-11-2004 18:37
How long can car idle on a tank of gas? sanddrag Chit-Chat 11 13-09-2004 12:46
Bear with us ... its being fixed archiver 1999 6 23-06-2002 22:36
