Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
Unread 23-12-2008, 19:34
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Wago connectors
I was wondering where you can order more power wago connectors that connect the modules and the digital sidecar to the power distribution board.
Unread 23-12-2008, 20:14
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Wago connectors
I believe AndyMark will be stocking them since they are kind of hard to find the exact ones.
Unread 23-12-2008, 21:27
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Wago connectors
Wago is a brand name that started the "spring clamp" style terminal block. There are several automation vendors that supply spring clamp or sometimes called cage clamp terminal blocks.
Unless the KOP regulates specific "Wago" brand, you should be able to obtain other brands in the same style:
Several names come to mind:
Automation Direct would be the easiest online store:
Spring Terminals
Allen Bradley offers Spring Terminals, though normally need to visit an Allen Bradley distribution house, such as in my area "Indiana" Wabash Electric, Kendal Electrical, Kirby Risk, etc.
Spring Clamp IEC 1492 Series
Phoenix Contact is another place to get Spring Clamp terminals.
Spring Clamps
Weidmuller is the Germany company terminal blocks.
Tension Clamp Style
I could probably go on and on....
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-12-2008, 23:33
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Wago connectors
Elgin is correct. Andy posted on this subject the week before last.
And so is Chris. It is good that FIRST has included this popular style of connector.
Richard Wallace
since 2003
Unread 24-12-2008, 09:09
Re: Wago connectors
The KOP may or may not, but the early shipment of the Control System does specify the WAGO brand.
As far as a suitable replacement if a WAGO one can not be found, that is to be determined by FIRST.
(It is to note, that it is highly unlikely they will not be available to everyone, since AndyMark should have them available for everyone on demand - That's the plan anyways)
Unread 24-12-2008, 13:01
BrentJ BrentJ is offline
BrentJ has a spectacular aura aboutBrentJ has a spectacular aura about
Question Re: Wago connectors
Looking at past years info I would think they would only use the Wago brand just to keep things simple for the robot inspectors.
Imagine an inspector trying to check an electrical system if they have to remember which way the connectors appear when open / closed. Also how would the inspector know if a non-wago connector was rated for the correct current handling capacity?
I thought that these should be fairly easy to buy from electrical wholesalers?
Brent
Unread 25-12-2008, 22:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Wago connectors
Since these are fairly low current applications - he is talking about the grey thingies that go to the digital/analog/pneumatic systems = that current capacity isn't a serious concern in this application. An amp or six shouldn't be a problem.
As for buying them, if you need 100 of them they should be easy to order, but unlikely they are stocked items.
Lost Wago power connector 734 102 falconmaster General Forum 14 06-01-2009 13:01
help with wago falconmaster Electrical 9 26-12-2008 14:31
Connectors. ForgottenSalad Electrical 4 12-02-2006 13:35
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
