Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Unread 24-12-2008, 10:31
Re: "Pinger" diagnostic program to test robot network.
Very nice, immediately useful application of LabVIEW.
I downloaded the source posted and only got an executable.
Unread 24-12-2008, 11:58
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Oops, that was an early zip. The latest one was in a different folder.
I uploaded the latest, but can't seem to delete the original attachment.
Use the one that says "Full Source".
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 24-12-2008, 21:39
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
cool. thanks.
Having the extra overhead of all that pinging will just slow it down.
I hadn't thought about that. I will keep that in mind. Thanks again.
Unread 09-01-2009, 18:59
Marlfox's Avatar
Marlfox Marlfox is offline
FRC #1566 (Ammoknights)
Team Role: Electrical
Marlfox is an unknown quantity at this point
thank you for the pinger!!!I freakin love you the only problem is that our cRIO is not pinging back to us, so we must have a problem with the cRIO. were re-imaging it now. I will be back if it doesn't work
You're about to be struck by a vehicle!
Unread 10-01-2009, 01:19
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
I have also seen problems with the cRIO not pinging back in a timely manner. I will ping the cRIO and get "unreachable" 3 or 4 times before the cRio returns a response. During those tests , I can always ping the DS, Router and Bridge with no problem.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 25-01-2009, 16:15
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
I was also trying to make a program with a vbs script that does that. It comes to something like this:
set WshShell = CreateObject("WScript.Shell")
PC = Not CBool(WshShell.run("ping 10.2.47.6 -n 1 -w 150 " & vSystemIdentifier,16,True))
DS = Not CBool(WshShell.run("ping 10.2.47.5 -n 1 -w 150" & vSystemIdentifier,0,True))
router = Not CBool(WshShell.run("ping 10.2.47.4 -n 1 -w 150" & vSystemIdentifier,0,True))
bridge = Not CBool(WshShell.run("ping 10.2.47.1 -n 1 -w 150" & vSystemIdentifier,0,True))
cRIO = Not CBool(WshShell.run("ping 10.2.47.2 -n 1 -w 150" & vSystemIdentifier,0,True))
If PC = True and DS = True and router = True and bridge = True and cRIO = True Then
'successful
msgbox "It is Working",vbOkOnly
end if
if not PC = True and DS = True and router = True and bridge = True and cRIO = True then
'Unsuccessful ping
msgbox "Somthing is not Working"
End If
If PC = False then
msgbox "Please fix PC adress",vbRetryCancel
End If
If DS = False then
msgbox "Please fix DS adress",vbRetryCancel
End If
If router = False then
msgbox "Please fix Router adress",vbRetryCancel
End If
If bridge = False then
msgbox "Please fix bridge adress",vbRetryCancel
End If
If cRIO = False then
msgbox "Please fix cRIO adress",vbRetryCancel
End If
pic: Team 4 Robot "Tipping Test" David Brinza Extra Discussion 11 25-08-2007 18:02
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
CMUCam blink test "blinktst.ic" mzainon Programming 1 22-04-2005 16:20
Program error - "can not fit the section" miketwalker Programming 9 20-02-2005 01:21
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
