Go to Post If you don't have a butt to fill that seat, you don't need it. When the butt arrives, we'll make room. - DonRotolo [more]
Unread 24-12-2008, 16:50
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: surefire ways to break you robot
hmm...
blame it on the programmer until the point where he needs an extensive break half way through the qualifying matches. Only to realize it was the mechanical peoples fault who needed to shave down some metal to fit within the size limits, while the piece is in the up position which is strategically located right over the electronics panel... which makes the autonomous go insane which causes the robot to suffer extensive mechanical damage from a run in with a wall in the middle of the playing field....
or short and sweet: BLAME IT ON THE PROGRAMMER SINCE HE DID NOT WRITE CODE THAT FIXED MECHANICAL PROBLEMS!!!
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
pic: strange ways you test stuff out? DarkFlame145 Robot Showcase 1 13-01-2008 15:10
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" Mr MOE General Forum 6 09-02-2007 08:40
What do you do when its time to take a break from building?? Leo 1529 Chit-Chat 23 13-02-2006 00:26
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 3 15-02-2005 11:38
