Go to Post For fun, someone ought to spread out a bunch of petri dishes or something all over a regional and see what you bring home with you. Or not. - KathieK [more]
Unread 24-12-2008, 19:35
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: my version of a wooden chassis
Originally Posted by squirrel View Post
There is no need to have as little pressure on the shaft as possible, if you make the axle shaft strong and well supported. If the shaft is short and large diameter and well supported, it can take a lot of load!
The neat thing about the wood chassis concept, is that you can build a couple of them, using different designs, for not much money. Then you can see how they work.
but wouldent having the wheels directly driven do both jobs at the same time and be stronger and lighter?
ill see if i can get back to home depot and get some more wood,
ill try building your design and see what happens
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
pic: Wooden Rack Wetzel Extra Discussion 3 07-01-2007 16:33
pic: Wooden Rack - Center ebmonon36 Extra Discussion 2 07-01-2007 06:26
pic: Wooden Wheel Elgin Clock Extra Discussion 13 10-05-2006 09:13
pic: Wooden Robot LetsGo810 Robot Showcase 9 27-02-2006 13:39
pic: Wooden Thunder, Team 1294 Rick TYler Robot Showcase 11 23-02-2005 21:40
