Go to Post It's always nice to have the outside party take a look at your code because one of two things can happen: 1. They write it better. 2. They find your stupid mistake. - [more]
Unread 19-12-2008, 12:56
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
"Pinger" diagnostic program to test robot network.
Hi
After configuring my fair share of new FRC2009 networks, I realized that a tool that showed me the current state of my robot network would have been reallllllllly helpful.
So I decided to flex my new LabVIEW muscles and create such a tool.
I've attached the resulting "Pinger" program.
Simply enter your team number at the top and it will continually ping where your various devices should be. Green means OK, Red means Not found.
I find that if you start at the top of the list and work down you can validate your network from the PC to the robot.
I also added a box at the bottom for checking "unconfigured" devices. This can be used to check for any device on the default "192.168.1.x" network. Keep in mind that the PC has to be on this network to see these devices.
Note: your robot may seem to run fine with only some of the BIG LEDs green, but to get ALL the functionality (Dashboard etc) you should strive to get ALL the BIG LEDs green.
Phil Malone
http://www.GEARSinc.org
Unread 19-12-2008, 13:00
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: "Pinger" diagnostic program to test robot network.
Phil,
Is there any way to "see" the camera that's attached to the other Ethernet port of the cRIO?
Are there any configuration bits that could also be extracted and displayed (eg cRIO status regarding run-on-startup programs, camera configuration settings, cRIO and DS and other software versions)?
Great tool!!
THANKS!!
Russ
Unread 19-12-2008, 13:35
PhilBot's Avatar
AKA: Phil Malone
Originally Posted by Russ Beavis View Post
Phil,
Hi Russ.
I think the cRIO code has to read the camera and route it to the PC, as in the way the dashboard operates. But... That's what the Dashboard is for
I just wanted a go/no-go test to let me know the network components were at least ready to run.
Once the network is running, all the other tools can be used.
Phil
Phil Malone
Unread 19-12-2008, 19:49
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Great job! used it to verify all my connections. Thanks
Unread 20-12-2008, 17:27
PhilBot's Avatar
AKA: Phil Malone
To make it easier to keep track of program updates, I've added the Pinger program to a white paper I just uploaded.
To get the latest version jump to:
http://www.chiefdelphi.com/media/papers/2177
Or search White Papers for "GaCo Pinger"
Phil.
Phil Malone
Unread 24-12-2008, 06:14
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
wow cool program. Could really come in handy.
One question though, since this was written in labview, could you release the labview "source code"? Maybe even put in in a VI?
I'd rather have this embedded into the dashboard instead of having to run a separate application. Thanks.
Unread 24-12-2008, 09:44
PhilBot's Avatar
AKA: Phil Malone
I really didn't think anyone would be that interested, but I've added the Source to the White paper. Hoepfully, since you've asked for it, you'll take the time to download, unzip, and view the program.
The latest dashboard (Update 2.0) already includes the code to check your local IP to ensure that it will receive robot data.
I personally don't think that the other ping statuses belong on the dashboard.
Pinger is really only needed to get up and running. Once your network is properly setup, it's not needed anymore. On the other hand, the dashboard is really needed to test your robot functions, and will be constantly changing as you develop your code. Having the extra overhead of all that pinging will just slow it down.
Feel free to add it, but I really think it's best used as a stand-alone program
Phil Malone
Unread 24-12-2008, 10:31
Very nice, immediately useful application of LabVIEW.
I downloaded the source posted and only got an executable.
Unread 24-12-2008, 11:58
PhilBot's Avatar
AKA: Phil Malone
Oops, that was an early zip. The latest one was in a different folder.
I uploaded the latest, but can't seem to delete the original attachment.
Use the one that says "Full Source".
Phil.
Phil Malone
Unread 24-12-2008, 21:39
keen101's Avatar
Ubuntu Linux User
cool. thanks.
I hadn't thought about that. I will keep that in mind. Thanks again.
Unread 09-01-2009, 18:59
Marlfox's Avatar
Marlfox Marlfox is offline
FRC #1566 (Ammoknights)
Team Role: Electrical
Marlfox is an unknown quantity at this point
thank you for the pinger!!!I freakin love you the only problem is that our cRIO is not pinging back to us, so we must have a problem with the cRIO. were re-imaging it now. I will be back if it doesn't work
You're about to be struck by a vehicle!
Unread 10-01-2009, 01:19
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
I have also seen problems with the cRIO not pinging back in a timely manner. I will ping the cRIO and get "unreachable" 3 or 4 times before the cRio returns a response. During those tests , I can always ping the DS, Router and Bridge with no problem.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 25-01-2009, 16:15
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
I was also trying to make a program with a vbs script that does that. It comes to something like this:
set WshShell = CreateObject("WScript.Shell")
PC = Not CBool(WshShell.run("ping 10.2.47.6 -n 1 -w 150 " & vSystemIdentifier,16,True))
DS = Not CBool(WshShell.run("ping 10.2.47.5 -n 1 -w 150" & vSystemIdentifier,0,True))
router = Not CBool(WshShell.run("ping 10.2.47.4 -n 1 -w 150" & vSystemIdentifier,0,True))
bridge = Not CBool(WshShell.run("ping 10.2.47.1 -n 1 -w 150" & vSystemIdentifier,0,True))
cRIO = Not CBool(WshShell.run("ping 10.2.47.2 -n 1 -w 150" & vSystemIdentifier,0,True))
If PC = True and DS = True and router = True and bridge = True and cRIO = True Then
'successful
msgbox "It is Working",vbOkOnly
end if
if not PC = True and DS = True and router = True and bridge = True and cRIO = True then
'Unsuccessful ping
msgbox "Somthing is not Working"
End If
If PC = False then
msgbox "Please fix PC adress",vbRetryCancel
End If
If DS = False then
msgbox "Please fix DS adress",vbRetryCancel
End If
If router = False then
msgbox "Please fix Router adress",vbRetryCancel
End If
If bridge = False then
msgbox "Please fix bridge adress",vbRetryCancel
End If
If cRIO = False then
msgbox "Please fix cRIO adress",vbRetryCancel
End If
pic: Team 4 Robot "Tipping Test" David Brinza Extra Discussion 11 25-08-2007 18:02
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
CMUCam blink test "blinktst.ic" mzainon Programming 1 22-04-2005 16:20
Program error - "can not fit the section" miketwalker Programming 9 20-02-2005 01:21
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
