Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 23-12-2008, 13:12
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
FRCLabVIEWUpdate2.0.zip is on NI site.
Did I sleep through the announcement of Update2.0?
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
FRCLabVIEWUpdate2.0.zip is posted on NI, is it good to go?
Has anyone tried it?
Unread 23-12-2008, 13:25
Re: FRCLabVIEWUpdate2.0.zip is on NI site.
I hadn't heard about it yet. How did you stumble across it? What bothers me is that it looks like it was made available in November, yet there's been no obvious statement from anyone official that it even exists.
The download process I went through for the first update required me to provide my email address. I guess I assumed that the point of doing that would be so that I would receive announcements of updates like this.
I won't be able to install it until next week at the earliest. If anyone does try it before then, I'd like to know whether it requires an internet connection to complete the process. It's a lot less convenient to bring the team's programming computer to the update rather than the other way around, but it can be done if necessary.
Unread 23-12-2008, 13:35
AKA: Randy
There had been comments that an update was coming early this week, so I clicked on the update link and found 2.0.
Unread 23-12-2008, 13:43
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The URL stayed the same from the first to the second update, so all links now point to the second update. Someone had to notice sooner or later
I'm pretty sure it's safe to install, but we'll probably hear from FIRST in a few hours/days?
Unread 23-12-2008, 13:55
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
From the README_FRC.html file included with this distribution:
This file contains information to introduce you to the FIRST Robotics Competition (FRC) Software 2009 Update 2. The FRC Software Update 2 is a mandatory update to the FIRST Robotics Competition Software 2009 release...
Sound to be legitimate to me.
Also, it looks like we need to download a new image for the cRio. Additional features and changes are included.
New Features and Changes
The LabVIEW portion of the FIRST Robotics Competition (FRC) Software 2009 Update 2 includes the following new features:
The Dashboard Main VI in the FRC dashboard project has an updated analog data display, and the Dashboard Main VI now logs the history of the User Data you receive from the robot. Click the FRC Dashboard Project link in the Getting Started window to create a new FRC dashboard project. Refer to the FRC Dashboard Project section of Chapter 4, Using the FRC Framework, of the LabVIEW Robotics Programming Guide for the FIRST Robotics Competition for more information about using the FRC dashboard project.
Use the Ultrasonic VIs to measure the distance between an ultrasonic sensor on the robot and the closest object in front of the sensor. Refer to the LabVIEW Help, available by selecting Help»Search the LabVIEW Help, for more information about the Ultrasonic VIs.
A new image for the CompactRIO device is available. Download the FRC_2009_v7.zip image to the CompactRIO device by selecting Tools»CompactRIO Imaging Tool to launch the CompactRIO Imaging Tool dialog box and selecting FRC_2009_v7.zip from the Select Image list. Refer to Chapter 3, Configuring the Camera and the CompactRIO Device, of the LabVIEW Robotics Programming Guide for the FIRST Robotics Competition for more information about using the CompactRIO Imaging Tool.
The following issues exist in the LabVIEW portion of the FIRST Robotics Competition software when you upgrade from the Update 1 or earlier release.
FRC dashboard projects you created in previous versions of the FIRST Robotics Competition software are no longer compatible with the dashboard data the FRC robot sends to the host computer. You must create a new FRC dashboard project by clicking the FRC Dashboard Project link in the Getting Started window.
Unread 23-12-2008, 19:32
No Internet connect was used in the installation of this update.
Which makes sense because we're on our private 10.x.x.x network.
Having to have two networks active would really limit the machines this could be installed from.
We're no longer offered the choice of robot # in the FRC cRIO Imaging Tool, and installation of the update also removed older cRIO update files.
Unread 24-12-2008, 01:48
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
To the best of my knowledge (Beta Forums) Currently the DS does not support more than one robot. This feature was temporarily removed until that feature is implemented for the DS
-Borna Emami
Team 0x27
Unread 24-12-2008, 09:40
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Other than creating new Dashboard projects, do we need to create new robot frameworks? Are there changes to RobotMain.vi or any of its subvi's?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 24-12-2008, 14:44
The way the dashboard VIs are called in RobotMain changed.
I was able to run the old project without any changes. I did end up starting over, though. Every time we start over, it gives us a chance to restructure the code better. I may not want to do that later, but pre-kickoff is the perfect time to do things like that.
Unread 24-12-2008, 15:41
I don't see anything in the high-level framework for the cRIO side that changed.
You might want to rebuild your cRIO projects too and redeploy them. The Update changes will be pulled in as dependencies, but they are already resident on the cRIO.
The developer's have been very busy...
A bunch of updates to the FPGA and low-level dependencies in the vi.lib: Watchdog, Victor, Jaguar, Solenoid, Serve, Relay, RobotDrive, PWM, MotorControl, Joystick, Encoder, DigitalModule, Camera, AnalogModule, AnalogChannel.
Unread 25-12-2008, 12:31
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Is it necessary to install update 1 before installing update 2? More generally (assuming there will be at least an update 3), do you need to install all the updates, in order, or can you just skip to the end and only install the latest updated?
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 25-12-2008, 12:36
The answer is in the description of the download:
Originally Posted by http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
...You do not have to install the first update in order to install this update. This update incorporates the changes from the first update.
Unread 01-01-2009, 19:23
sirlancerbots sirlancerbots is offline
FRC #2977
sirlancerbots is an unknown quantity at this point
Image will not take. We received error 56. Lost the IP. Had to use Ethernet Device to put IP back in. Any ideas on how to load new image?
Thanks,
Unread 01-01-2009, 19:36
FRC #2977
Yes the FW needed to be turned off! it now works!
pic: Zip ties man, zip ties! buss Extra Discussion 2 09-04-2008 07:14
zip ties CCCP Chit-Chat 0 03-02-2008 01:11
[FTC]: Zip ties HRobotics FIRST Tech Challenge 9 29-11-2007 15:05
Zip ties tinderfitles VEX 2 24-10-2006 16:47
Zip Ties Robot935 Technical Discussion 12 11-02-2002 10:58
