Go to Post FIRST is NOT just about robotics. It is about the growth of leaders - of Gracious Professionals... - MysterE [more]
Unread 26-12-2008, 00:12
Cptn Patches537 Cptn Patches537 is offline
AKA: Eric Larson
FRC #0537 (Charger Robotics)
Cptn Patches537 is infamous around these partsCptn Patches537 is infamous around these parts
Send a message via AIM to Cptn Patches537
Computer (Windows XP) Problem
Hello all, hoping the strategy of combined knowledge and experience can yield some answers here.
The Problem: Windows XP will not start, I receive an error saying there is a "Bad Image Checksum" or something..related to the file secur32.dll
This resulted from the windows update from SP2 to SP3, which caused some crazy conflicts with Threatfire, AVG Free, and Firefox...basically firefox wouldnt start after the update because apparently Firefox 3 and Threatfire arent compatible...and in deleting Firefox to attempt a reinstall..somehow said file was lost or corrupted.
What I have tried: I attempted to boot windows off of a windows boot/update disk to recover the lost file through the recovery console HOWEVER...prior to the screen giving the option to select recovery console I receive an error claiming that my drive may be infected and that I need to run the CHKDSK function.
The error code is as follows STOP: 0x0000007b(0xF78D2524, 0x00000034, 0x00000000, 0x00000000)
From what i understand...CHKDSK cannot be run until the recovery console is reached...
I read somewhere that to do this would require transplanting the drive into another computer as a secondary HD to run CHKDSK...at which time I would likely throw in the towel and take it to a professional
Comments? Questions? HELP?
Thanks in advance for anything....Larson
2007: -Wisconsin Regional Chapions
-Regional Engineering Inspiration
-Regional Rockwell Innovation in Control Award
2006: -St. Louis Regional Champions
-K,P+B Award at St. Louis and Wisconsin
2005: -Midwest Regional Champions
2004: -St. Louis Regional Champions
Unread 26-12-2008, 00:17
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Computer (Windows XP) Problem
This might be useful: http://support.microsoft.com/kb/324103
Unread 26-12-2008, 03:26
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
The first thing you should do is move the drive into an external enclosure, not internal so there is no chance of booting from it, and backup everything you care about.
A quick search doesn't show that this issue is known to be related to SP3, so we'll assume its unrelated to what you were doing.
It is very likely this is physical HDD damage. If the machine is >3 or 4 years old this is not uncommon.
The easiest way to rule out this option is to run a HDD diagnotic tool. I use SeaTools which is free from Seagate, but works on almost any drive. There is a Windows version if you move the drive to another machine, and there is a bootable DOS version which can be run from a CD or floppy. You should run this to determine if the drive if physically healthy.
From SeaTools you should run the following tests (Depending on the size of the drive this could take over a hour.)
Run the short test, if that fails buy a new drive. If the itsucceeds then run the long test.
If the long test fails buy a new drive.
If the long test succeeds after repair run the test again, if it finds more errors buy a new drive.
If the long test succeeds you can be fairly sure its a software issue.
If this is a software issue you may be able to recover your machine, but you probably won't be able to get the machine very stable. My recommendation is run fixmbr from recovery console, delete ALL partitions on the drive, recreate and format any partitions, then reinstall Windows. However if you don't want to do that there are two things you can try.
Either of these options may cause data loss/corruption, so make sure you've backup up your data!
1. It could just be a MBR corruption issue, this could be due to a virus, HDD damage, or something else. Assuming the HDD is still functional this can be corrected from Recovery Console if you can get it to load, by using the fixmbr command.
2. You can try doing an over-the-top installation of XP. This would replace the system file with original ones. This could save files, but application installs and system configuration would be lost.
Eric Haskins KC9JVH
Unread 26-12-2008, 06:17
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Your issue sounds moderate serious.
I think you will either need to reinstall windows, or try and use a windows recover disk to "repair" (it will actually replace) the broken files.
If it were me, i would use a Linux Live-CD to access the drive and copy my valuable data off first. Or mount the drive as a SLAVE HD in another windows machine and copy data off that way.
In either case i think you will want to back up data, and then either attempt to repair or reinstall.
Unread 26-12-2008, 08:17
I will go along with Eric on this one. It sounds coincidental that a hard drive failure occured at the same time you were performing an update but it happens. Have you tried to use the manual boot sequence to go back to the last known good bootup?
From Microsoft help...
To start the computer using the last known good configuration
Print these instructions before continuing. They will not be available after you shut down your computer in step 2.
Click Start, click Shut Down, and then, in the drop-down list, click Shut down.
In the Shut Down Windows dialog box, click Restart, and then click OK.
When you see the message Please select the operating system to start, press F8.
Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
Notes
Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
NUM LOCK must be off before the arrow keys on the numeric keypad will function.
Unread 26-12-2008, 11:09
AKA: Eric Larson
Alright...yes, ive tried to boot from the last known good configuration and that didnt work. I've also run Dell's full HD Diagnostic which took ~4-5 hours and it came out clean.
If i could just get to recovery console Id be golden b/c then i can just repair that .dll and everything should be hunky dory but i cant get to recovery console b/c it tells me that there is some sort of error and i need to run CHKDSK before i get there...that is the error code i originally listed
i mean..i cant even get into windows period so...
i guess my biggest question is can you run CHKDSK prior to the recovery console?
what would i do to save the files i have on it? Move the HD to another machine and drag and drop off of it?
Unread 26-12-2008, 11:13
matt91 matt91 is offline
FRC #1779 (G-F.O.R.C.E.)
matt91 is an unknown quantity at this point
Send a message via AIM to matt91
i would just delete everything, repartition the disk(s) and reinstall a fresh copy. If you need your software, you could always just reinstall it- most companies understand if you need a new serial # or activation code, just give them a call.
Cost of 6 Jolt drinks for 3 days: $72
FITST Registration Fee: $6,000
Cost of Coffee for build season: $94.54
Cost of Programming a robot: Sanity
Cost of spenging 3 days whith people who are just as crazy as you: Priceless
Team 1779- South Boston Robotics
G-F.O.R.C.E.
Generations of Futuristic Original Rational Conceptualized Engineering
Unread 26-12-2008, 11:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
That's how I usually do it.
Unread 26-12-2008, 13:59
First off, I have an aversion to wiping a previously working copy of anything to fix an unknown problem. If you can't get to a safe mode it is possible you have contracted a virus. If so, the virus is producing the error message or it has damaged needed boot files or the boot sector of the drive in the process. You just don't know at this point. I would check the virus sites and see if any of the newer viruses have this signature and what it would take to fix it.
I am guessing that you have tried the F8 during the boot sequence to get to the "choose operating system" text screen and that is not working, correct?
Unread 26-12-2008, 14:03
AKA: Eric Larson
yes when attempting to boot safemode i get the same secur32.dll is corrupt Bad Image Checksum message.
When booting from CD i get the run CHKDSK message which doesnt make sense to me b/c im..booting from the CD...so why should my HD matter...and it seems to me the only way to run CHKDSK on it is to transplant the HD to another computer...at which point I would likely just transfer all my files to a safe location and start over...i dunno....
Unread 26-12-2008, 14:11
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
I have had this problem with one of my computers every time I try to upgrade to SP2 or SP3. Finally gave up. I get into safemode and do a system restore. Works every time. There are no lost files.
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 26-12-2008, 14:13
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
If you can boot from the Windows CD, you can do a "repair install". after you boot, DO NOT GO TO THE REPAIR CONSOLE, go ahead And tell it to install windows. It will then do a disk check and tell you that windows already exists on this partition and ask if you want to repair. Say yes. It looks like it is reinstalling windows, but it's not. It will replace all system files. I think it will return you to the service pack level of the install CD, not sure on that. If you google "repair install XP" you should find lots of info.
Good luck.
Former Mentor Team 1771
Former mentor Team 4509
Unread 26-12-2008, 14:20
martin417's Avatar
AKA: Martin Wilson
Here is a useful link:
http://www.michaelstevenstech.com/XPrepairinstall.htm
Unread 26-12-2008, 14:25
Eric,
In doing some research there is a variety of known virus problems that disguise themselves as this Windows security file. If you can get the options screen and can select DOS instead of Windows or Safe mode. The file should be in the C:\Windows\System32 folder. Check the date and size of this file and any other file os a similar name and/or size with a date about the time of your problem. It is possible that the virus has renamed your origianl file and substituted it's own. Simply deleting the file will not fix the problem as so many Windows processes use this file.
Unread 26-12-2008, 14:31
keen101's Avatar
Ubuntu Linux User
now there's an idea!
Try to replace the file with a known good one from a working windows machine.
If it were me it would take about 2 min's with a Linux Live-CD, but i assume you either know nothing about Linux or really prefer windows.
If that's your case you could hook it up to another windows system, and try to copy it over, but considering it's a critical system file it might be in use and unable to copy over.
Re-Install Windows with Inventor on Computer DMetalKong Inventor 3 03-06-2008 08:14
Windows Vista Networking Problem mtaman02 Chit-Chat 13 10-06-2007 20:33
Winzip and Windows XP problem, please help sanddrag IT / Communications 9 15-12-2005 16:13
Computer Problem Mike Schroeder Chit-Chat 10 04-12-2005 12:17
Windows Xp networking Problem BobcatProgramer IT / Communications 17 30-09-2005 15:27
