Go to Post I...want...to...go...to...Champs. REALLY REALLY BADLY. - CalTran [more]
Unread 24-06-2002, 00:04
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
How about a Trantorque !
Posted by Ed Sparks at 2/2/2001 10:15 PM EST
Engineer on team #34, The Rockets, from Bob Jones High / New Century High and DaimlerChrysler.
In Reply to: Connecting hub sprockets to shafts
Posted by Patrick Dingle on 2/2/2001 7:17 PM EST:
Check out those trantorques on page 384 of the small parts catalog. A little costly but very easy to work with. Keep an eye on the "Max Torque" values in the chart and be sure to hold the 0.0015" tolerences on the shaft and bore. I always have our machine shop bore our sprockets/gears on a lathe. You'll see a bunch on team 34's 'bot this year and they are "fasteners" so they don't gig your SP budget. You can buy these a little cheaper from Fenner Drives and even buy an 11mm version that works well on the van door motor shaft.
[IMG] code is Off
modifying sprockets gail OCCRA 3 05-10-2002 12:13
shafts, gears and wheels.... archiver 2001 13 24-06-2002 04:09
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
5/16" cold steel shafts... archiver 2001 3 23-06-2002 23:17
Which form of connecting a rod to a wheel is the best? SilverStar Technical Discussion 2 27-03-2002 20:30
