Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 25-12-2008, 18:42
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Cheap encoders
Here is some more detail on these encoders.
Metal housing, bushing not bearings, .25 in dia. shaft, some resistance to rotation but not much.
I processed this picture to bring out details that would otherwise be difficult to see.
Unread 26-12-2008, 01:18
Re: Cheap encoders
Mark McLeod was right. They're intended for use in a control panel with a knob attached for people to turn. They'll "work" as a drive shaft encoder, but they probably won't be very robust.
Unread 26-12-2008, 01:50
billbo911's Avatar
Re: Cheap encoders
Most definitely decent quality, by that I mean not garbage, but not the type I would used for a drive train either. I plan to connect a pair to a couple globe motors we have attached to our '09 control system tomorrow. This will allow our programmers to figure out exactly how to code for them. It will also allow them to see if they can come up with an autonomous routine mock up. Heck, at $4/ea., I could care less if they fail in just a few days use, as long as the students learn how to use encoders for various applications.
Unread 26-12-2008, 08:41
Gdeaver Gdeaver is online now
FRC #1640
Re: Cheap encoders
I recieved mine last week. Yes, they are sleve bearings, but I had no problem hooking them up and getting counts up to about 300 rpm. I would not want to use them at high rpm like controlling the velocity of a ball shoot like in aim high. My thought is that they would be fine at the rpm that they would see if the AM tough box is in the KOP and they ship with the encoder 1/4" shaft extension. The key point is the mounting and coupling. Stress on the shaft would eventual cause failure. The other thing is if they maintain a crisp square wave at higher RPM. I would at this time not write them off.
Unread 26-12-2008, 13:43
Ivan Helmrich's Avatar
Ivan Helmrich Ivan Helmrich is offline
FRC #1775 (Tigerbytes)
Ivan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to beholdIvan Helmrich is a splendid one to behold
Re: Cheap encoders
I too purchased a few of these. I really don't understand the quality concerns people are expressing. While this exact model number isn't available, other comparable models of the same brand are available from Mouser Electronics for about $51.67. Not a cheap part at all. Mechanically, they seem more robust than the plastic housed US Digital encoders I have. The published specs seem to be comparable to the popular US Digital part as well. (I'm not knocking US digital, I like their parts and will almost certainly be using some this year.)
It's true, they have sleeves and not ball bearings. This doesn't reflect quality as much as intended purpose however. Sleeve bushings work just fine in the right application.
So, what application? With a life of 10,000,000 rotations at 300 rpm, I get something like 550 hours of operation, or about 16000 FRC matches. Our robot won't see that many. 300 RPM is a little slow for a drivetrain but they should be fine for just about any other lower speed application. I'm pretty sure I'll be using these somewhere this year too.
So, at $4 each, I couldn't resist taking one apart to see what is inside. I slipped the snap ring off the shaft and gently pried the back cover off. It came right apart with snap. The disk is what appears to be etched stainless and the circuit board is a simple affair without any screws to come loose. The drag on the shaft is due to the grease used and the good fit of the sleeve and shaft. So this leads me to another thought.
At the most, I think our robot could only see about 100 matches. More likely, fewer than half that. So now, I can think about de-rating. If I put these on my drivetrain, they might rotate up to 500 RPM or so. Not even twice the rated speed. I'm willing to bet that this won't reduce the life by a factor of 160, so I should be good to go.
The only issue I see is if as mentioned by Gdeaver, the wave form goes soft at higher speed. I'll bet not, but I'll put a scope on one to make sure.
Would I use these on the drivetrain of a bomb disposal robot at similar speed? No way! Lives could be at stake. To save a few bucks my team can use elsewhere? You bet. It's a good exercise in value engineering. YMMV
“The knowledge of what is relevant, what is not and the skill to cleverly work around or approximate solutions is the essence of engineering.” - James C. King
Encoders..... manderson5192 Programming 4 07-02-2008 10:10
encoders benjamin1748 Programming 6 07-02-2007 22:37
