Go to Post It would be a (relatively) level* playing field *...though it seems like the actual field will be anything but level. - Jacob Bendicksen [more]
Unread 26-12-2008, 16:55
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
Question about QuadEncoders [C++]
what does the Get function in Encoder class return? detailed explaination if you can, please
Unread 26-12-2008, 18:24
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Question about QuadEncoders [C++]
from Encoder.cpp:
 * Gets the current count.
 * Returns the current count on the QuadEncoder.
 * @return Current count from the QuadEncoder.
INT32 Encoder::Get(void)
	INT32 value = m_encoder->readOutput_Value(&status);
	wpi_assertCleanStatus(status);
	return value;
It returns the number of pulses received since the encoder was initialized or the count was reset.
Your other option is GetPeriod, which:
"Returns the period of the most recent Quad Encoder pulse in microseconds."
Unread 27-12-2008, 11:46
None #2669
well, but what happened if I change the direction, will the Get function give me the duplication of ticks or maybe the distance it passed?
Unread 27-12-2008, 11:54
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Get Encoder does not get "ticks". It reads the number of counts from it's initialization/last reset. As the encoder turns in its forward direction it increases the encoder counts, as it turns in its reverse direction it decreases the encoder counts (even going negative).
I am not sure if GetPeriod will return a negative encoder period or not.
___________________
- Tennyson, Ulysses
Unread 27-12-2008, 12:17
No, GetPeriod will not return a negative number. It simply returns time passed between the last two pulses.
And yes, Daniel is right about the values Get() returns.
question about judgeing legomaster3945 3D Animation and Competition 3 01-03-2008 23:40
A question about current.... Adam Y. Electrical 41 26-11-2004 21:46
Question about wheels Randy_Ai Technical Discussion 9 24-01-2002 17:14
Question about bumpers Randy_Ai Technical Discussion 2 23-01-2002 17:59
question about gyrochip wes16zeus Technical Discussion 3 13-11-2001 16:24
