#11
Re: pic: Madtown Marauders Wheel
It's not hard to use a wheel like this, but get ready for some machining. The easiest way I can think of is to make two plates that sandwich the wheel with half of the spoke profile milled into them each, so they fit snuggly into the wheel. Then use bolts to clamp the two plates together, trapping the wheel and using milled grooves and the spoke pattern to transfer the torque.
Then to power the wheel, either drill a hole pattern into these two sandwiching plates for a dead axle drive train, or make one of the pieces out of aluminum (the other could be polycarbonate to name an example) and broach it for a live axle. |
| pic: Madtown Marauders DT of DOOM-2 | R.C. | Extra Discussion | 19 | 10-01-2010 19:16 |
| pic: Madtown Marauders DT of DOOM-1 | R.C. | Extra Discussion | 2 | 27-12-2008 16:50 |
| pic: Madtown Marauders DT of DOOM-3 | R.C. | Extra Discussion | 4 | 16-12-2008 22:57 |
| pic: Madtown Robotics 07-08 Frame | R.C. | Extra Discussion | 4 | 09-07-2008 17:27 |
| pic: Madtown 1323 Proto 2 | R.C. | Extra Discussion | 12 | 20-06-2008 20:27 |
