Go to Post Dean: We encourage kids to learn about science, technology.... Colbert: And does that include creation science? Dean: .... Well we teach kids to be very creative..... - Kevin Sevcik [more]
Unread 12-26-2008, 12:38 AM
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: Madtown Marauders DT of DOOM-1
Unread 12-26-2008, 01:14 AM
Mike Nawrot's Avatar
Mike Nawrot Mike Nawrot is offline
NAwrot (a.k.a. jub jub)
AKA: Mike
FRC #0011 (MORT (Mount Olive Robotics Team))
Mike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really nice
Send a message via AIM to Mike Nawrot
Re: pic: Madtown Marauders DT of DOOM-1
I was working on a DT like this a few years ago (right after the 06 season, I believe). Only mine had 8 wheels, and both ends folded up. They were designed for one specific angle, and pneumatically controlled. If they are used elsewhere on the robot (or if you just have the weight), I'd strongly recommend using pneumatics to lift the end(s) of the robot. The complexity of the system is greatly reduced (ya know, less parts there are, the less parts there are that can break), and there's less stress in the system (you're currently overcoming gravity AND the gas shocks). Plus, the time it takes to prepare for ramp climbing is greatly reduced.
If you don't have the extra weight for the compressor, accumulators, etc, then I'd recommend either a belt driven system, or a spool with some sort of cable. Any motor could be made to do the job, it's just a question of how fast or slow, and how much weight for gearboxes you have. The amount of thought required for the motor option is several orders of magnitude higher than for the pneumatic options.
As for the hinges.. Bushings should be fine. The shaft in the bushings won't be rotating too quickly, so they should have a sufficient lifetime. Also, there shouldn't be much of a radial load on them, so they shouldn't seize up while in use. Simple, but effective, IMO.
I've supplied a link to a few images of the DT I designed a while ago. It's a smaller scale, and the outer wheels aren't driven (though the large scale one I was working did have 8 driven wheels) . I didn't put in the inner four wheels, but you can kinda guess where they would go. Unfortunately, none of the pneumatics are there or anything. But it looks cool.
Folding Drive Train
"Its not just good... its good ENOUGH..." "Talk to me in two weeks" "It has to be done by Sunday" "Let me tell you a little something about FLL..."
"Physics don't apply on MORT robots" "What's today's roofigog?!" MIT class of 2012
Unread 12-27-2008, 04:50 PM
joshy1323 joshy1323 is offline
AKA: josh anderson
FRC #1323 (madtown robotics)
joshy1323 will become famous soon enoughjoshy1323 will become famous soon enough
i question the balance when climbing. i question the ratio of usefulness to effort. and i question ur face. otherwise i have no complaints =P lets do this!
----1323 josh
pic: Madtown Marauders DT of DOOM-2 R.C. Extra Discussion 19 01-10-2010 07:16 PM
pic: Madtown Marauders DT of DOOM-3 R.C. Extra Discussion 4 12-16-2008 10:57 PM
pic: Madtown Robotics 07-08 Frame R.C. Extra Discussion 4 07-09-2008 05:27 PM
pic: Madtown 1323 Proto 2 R.C. Extra Discussion 12 06-20-2008 08:27 PM
pic: Wheel of Doom Paul Copioli Robot Showcase 24 02-03-2006 11:31 AM
