Re: pic: Madtown Marauders Wheel
Sorry - I do not believe they weigh .05 lbs - maybe someone made a mistake in where the decimal point belongs? Who told you or where did you read a spec that says it weighs that much - you should check your source again.
.05 lbs is less than 1 ounce. There are no materials known to us on earth that are that low in density that can hold 120 pounds in the configuration of that wheel. |
As for mounting the sprocket, I would go with Art's idea. U have the machining resources so get to it ![]() |
Sponsor donations are nice, but the parts always need to be evaluated against the alternatives. |
Preseason Madness Rocks! -RC |
You could always use them as idler wheels.
From what I've heard, the spokes at not meant to be torqued. Sure they may work fantastically as casters but until you can find a way to test how well the wheel takes torque, you can't trust them powered on a FRC bot. -Vivek |
#7
looks nice. but i agree with a lot of other people. in FRC i dont think it would survive. but off season stuff it would be great to work with. although for a wheel chair it may be great but think about when you put all of that torque on the center of that wheel. it would probable rip apart after a while.
| pic: Madtown Marauders DT of DOOM-2 | R.C. | Extra Discussion | 19 | 10-01-2010 19:16 |
| pic: Madtown Marauders DT of DOOM-1 | R.C. | Extra Discussion | 2 | 27-12-2008 16:50 |
| pic: Madtown Marauders DT of DOOM-3 | R.C. | Extra Discussion | 4 | 16-12-2008 22:57 |
| pic: Madtown Robotics 07-08 Frame | R.C. | Extra Discussion | 4 | 09-07-2008 17:27 |
| pic: Madtown 1323 Proto 2 | R.C. | Extra Discussion | 12 | 20-06-2008 20:27 |
