Go to Post will.i.am should be evangelizing FIRST, not vise-versa. - basicxman [more]
Unread 28-12-2008, 01:48
urg8rb8 urg8rb8 is offline
FRC #0108
urg8rb8 is an unknown quantity at this point
Help with updating firmware on Driver Station
Our team followed the firmware update procedure for the Driver Station correctly but for some some strange reason the Driver Station stayed in flashing mode (ie the screen where it says "DO NOT SHUT OFF!") for close to two hours. The instructions say that it takes about 3 mins to flash. We eventually had no choice but to cycle power on the device because it was obvious that something went wrong. Now the Driver Station looks like it tries to boot up but gets locked up with the "Kwik Byte" image on the screen.
Any ideas on how we could possibly bring it back to life?
Thanks for any help!
Unread 28-12-2008, 02:23
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Help with updating firmware on Driver Station
Check out these two threads:
http://www.chiefdelphi.com/forums/sh...ad.php?t=70213
http://forums.usfirst.org/showthread.php?t=10542&page=2
I would contact FIRST before paying for KwikByte to do anything in your specific circumstance as it sounds like you may have had a DS that was defective in some way.
One thing to check is the filesize of the update on your flash drive. If your file downloaded correctly it should be 2.19 MB.
Unread 28-12-2008, 02:45
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
As Vikesrock said you should contact FIRST about repairs, but the quickest way to get up and running may be to buy a replacement from AndyMark.
Eric Haskins KC9JVH
Unread 28-12-2008, 02:53
FRC #0108
Thanks for the replies. Our team verified that the bin file was the correct size. I believe we might have a defective Driver Station.
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
updating firmware on crio nickmagus Programming 16 17-12-2008 16:58
Trouble updating firmware AdamHeard FRC Control System 4 17-12-2008 09:22
Help with driver selection LBK Rules General Forum 28 04-02-2003 18:04
