Re: pic: Dual FP gearbox
They run a lot better if you run them a little loose... I think designing them at "pitch circle + .003" is a pretty good bench mark. Should be fine. -John |
(out of curiosity, how is there more efficiency from more space? I'm visualizing the rounded tooth profile rolling across another tooth, and not seeing how more space can help this. Care to clarify?) |
It was once explained to me that standard tooth profiles are NOT designed to run "happy" initially. They are designed to wear-in over time. Unfortunately for us, FRC Robots have a ridiculously short lifespan compared to more "industrial" applications. Adding a few extra mills to the axle spacing just serves as a replacement for this true wear-in. I'm not sure if this is true, or if it is just some urban legend. I know that the person who told it to me is someone I trust and respect VERY much. I also know you can "feel" the difference when spinning a gearbox by hand. The most important stage to reduce drag on, is the initial stage of the gearbox. This drag has the greatest effect on the output. -John Last edited by JVN : 12-28-2008 at 09:13 PM. |
We were considering the possibility of thinner plates, or possibly pocketing out the extra material or using delrin, but I didn't get around to it in this rendering. The total weight of both aluminum sideplates is 1.29 lbs, so the weight really isn't that bad (it could be reduced if necessary though). Total weight of the gearbox with motors and bolts is given by inventor to be about 5.3 lbs. This can be dropped to 4.6 by using aluminum AM cluster gears, and could probably get below 4 if we felt like pocketing sideplates and gears. I also thought about breathing holes for the motors and clearance holes for their screws, but didn't get around to putting them in this rendering. I doubt we would try to build a fisher price gearbox without them. Quote:
Our current plan is to try machining gearbox plates on a manual mill. We have access to a big one at our robot building facility, and there are a few high end ones in the AME department machine shop at my college. Hopefully we can keep all of the center to center distances within a thousandth, so it will probably work fine if we aim for 3 thousandths over nominal distance (I hope). If we get around to making something like this, we'll see how it turns out. |
That thing could become MUCH more compact if you're willing to have fancier side plates. There's no reason that the gears need to be in a straight line. Also, you can make the whole gearbox thinner (less distance between sideplates) by flipping the small and large gears on some of the axles.
Does that small blue gear need to be there? Doesn't look like it's doing anything. thanks, Vivek p.s. I'm a fan of heavily lightened 1/4" al sideplates. Besides being light and effective, they're absolutely beautiful. ![]() |
Earlier this morning I made one of the axles just for fun on my dad's clunky old lathe (backlash galore), and I was able to get the ends turned down to within .001" of where I wanted them. We'll see how it turns out on an endmill, though.And you are right about them being in a straight line; I'd like to do as few adjustments as possible. Quote:
The small blue gear is molded onto the big one (it's one piece). I would shy away from cutting it off... it would make the hub much weaker. It may survive, though. We were planning on torquing the blue gear until failure with a torque wrench to see just how strong it is. |
#7
chiming in on what JVN said:
We have done pitch dia. + .003 in the past and it has worked out well, and you can most certainly feel the difference between one that was designed with and without. I've also been told about the "urban legend" of gears being designed to wear in to a place where they are spaced properly. In my head it makes sense to me, because I see the gear teeth not reaching as far into the groove of the other gear. If there is less frictional loss (meaning less area of contact between the tooth of the gear and its corresponding groove) it would make sense it has a better efficiency. Of course this only applies to a certain degree, because at some point the gears are not going to be meshing properly. |
#8
As to using the FP plastic gear with two motors...we did a test with the torque wrench, a plastic gear in a vise, and a 3/8" hex shaft, to see if the hex hub in the gear could withstand the extra torque.
http://www.youtube.com/watch?v=dDD3U2Jle8Q |
#9
Looks like a great way to move an arm. I'm wondering, though, if replacing a few of the stages with a couple of Banebots planetary gearboxes would cut down size and weight sufficiently to be worth the cost.
We were looking at how we could take a couple FPs, then use the BBs to drive a worm gearbox for moving an arm. I know that kind of defeats the purpose of building your own gearbox from scratch... and I do have to admit that I enjoy seeing custom work more than just seeing yet another COTS gearbox... but when build time gets tight our team tends to head for the COTS solution. Jason |
#10
yes but these are the kind of things that can keep you busy in the off-season. make these and other components, so that when build season comes, you really just need to assemble together and then program it!
(sounds good in theory, but doesn't work out for our team) ![]() |
#11
Exercises like this are great for following through on ideas and learning about complications that may arise and how to best solve them. That's the stuff that useful during the build season -- not having a plug and play system of robot components at the ready. |
#12
is it really? i didnt know that
i guess i need to read the rule manual again.so you cant make like L brackets or anything before the season start? |
#13
You certainly cannot manufacture anything before the season starts and their are also rules governing the extent to which you may design components before kick off as well.
| pic: Dual Fisher Price gearbox | kajeevan | Extra Discussion | 12 | 12-09-2008 09:22 PM |
| pic: Dual FisherPrice Gearbox | vivek16 | Extra Discussion | 21 | 08-05-2008 11:37 PM |
| White Paper Discuss: Dual-motor, dual-speed gearbox | CD47-Bot | Extra Discussion | 8 | 04-05-2004 07:24 PM |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 10-07-2003 03:04 PM |
