Go to Post I hope to be able to say, "WOW, we put a working robot in the crate". - MrForbes [more]
Unread 28-12-2008, 17:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pulley questions
To others reading this post: Note what he says is the distance between cam and crank - one point two-nine inches. This is one very small engine.
Borna, you may get better results (and more informed responses) on a micro machining / engine hobbyist site. Steam engine folks also.
I am curious why you want to put the bigger pulley on the cam - in most 4-stroke engines the cam runs as twice the speed of the crank, not half the speed. Also, you MUST use a cogged ('timing') belt, since slippage will throw the timing off almost instantly. Or a chain.
As for tensioning - a belt tensioner just pushes against the belt to keep it tight, size is almost irrelevant.
pic: Pulley? dyanoshak Extra Discussion 6 12-01-2008 19:35
pic: Team 48 Drive Pulley A_Reed Extra Discussion 2 29-01-2007 12:26
Large CIM motor pulley size/series? Tim Skloss Technical Discussion 3 09-01-2007 22:36
big CIM pulley Rickertsen2 Motors 1 18-01-2006 11:41
Timing Belt and Pulley Joe_Widen Technical Discussion 4 16-01-2006 13:41
