Go to Post From what I've been told, it's BASIC. Just BASIC. Basic BASIC. Basically BASIC. To be basic, it's BASIC. - Aignam [more]
Unread 28-12-2008, 20:23
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
Mecanum Drivetrain design HELP!! PLEASE
i have been frying my brain the past weak trying to design a frame to run mecanum wheels and banebot gearboxes with the long shafts. what would be best to use. 1x1 square aluminum. or is there something that works better. we have been considering using 20mm extruded aluminum too. any help would be great. the main thing thats killin me is how to mount the motors in a way that will conserve wait and be strong at the same time
Unread 28-12-2008, 20:38
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Mecanum Drivetrain design HELP!! PLEASE
the kit chassis works good for a mecanum setup.....
search here for some ideas
http://www.chiefdelphi.com/media/photos/
once you mount them, its pretty simple to direct drive them from the BBs' output shaft(1/2inch hex I believe???)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 28-12-2008, 20:41
Sam2197's Avatar
Team Role: Driver
thanks i forgot that i can search pics. i now see that someone used a plate to mount to the gearbox and then to the frame. is there another way other then the kit chassis
Unread 28-12-2008, 20:44
gorrilla's Avatar
AKA: adam spears
theres lots of different ways,
you could, weld(or bolt), yourself together a square frame made of 1x1 square tubing
this is probobly the simplest way........
Adam Spears
Unread 28-12-2008, 20:47
Sam2197's Avatar
Team Role: Driver
thanks. we were trying to prototype this before kick off.. guess we're running out of time now.. uh oh..
Unread 28-12-2008, 20:50
gorrilla's Avatar
AKA: adam spears
it shouldent take that long, if you have all the supplies......
Adam Spears
Unread 28-12-2008, 20:53
Sam2197's Avatar
Team Role: Driver
well its christmas break at school and i cant exactly get into the shop to weld anything
Unread 28-12-2008, 21:13
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
2106 has used the old kit frame to prototype a drive just like you are suggesting. To mount the BB transmissions we used a Blank Gusset for non-90 degree angles (no holes) from IFI. We then tied the two front and two rear transmissions together with a few pieces of 1"x1" angle.
take a look at http://www.chiefdelphi.com/media/photos/32135 for what you can do without a machine shop :-)
pic: Concept Mecanum Drivetrain sdcantrell56 Extra Discussion 10 07-02-2008 11:56
Mecanum drivetrain programming problems Mr. Freeman Programming 4 21-03-2007 17:11
Please help with CAD design anthony113 Technical Discussion 12 19-06-2004 12:12
Please Help: FIRST Drivetrain xxmaddjxx Technical Discussion 5 24-04-2004 23:48
Save the rookies!!! Please help us to design a crate... Eugene Technical Discussion 7 05-02-2002 20:22
