Go to Post Stop being LAWYERS and start being ENGINEERS! - dlavery [more]
Unread 29-12-2008, 11:41
beefy1 beefy1 is offline
None #2669
beefy1 is an unknown quantity at this point
how to transfer the program to the crio?
I`m using wind river workbench, How can i pass the software into the cRIO?
thanks.
Unread 29-12-2008, 12:04
Racer26 Racer26 is offline
Re: how to transfer the program to the crio?
You have to set up the FIRST Downloader in the preferences under (i think) Window>Preferences
Then you use the FIRST menu, and go FIRST>Download.
Unread 29-12-2008, 15:58
None #2669
isn`t there any tool that is built in the windriver workbench?
Unread 29-12-2008, 17:02
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The FIRST Downloader IS built into Windriver. There's a FIRST menu at the top of the screen. I suggest you read the C/C++ Users Guide at http://first.wpi.edu/FRC/frcupdates.html
Unread 04-01-2009, 00:08
mgoodell6 mgoodell6 is offline
AKA: Mark Goodell
FTC #1902 (Exploding Bacon)
mgoodell6 is an unknown quantity at this point
I put together a checklist of sorts based on lessons we have learned with WorkBench. Let me know if this helps - no guarantees since it has been a long day.
Unread 04-01-2009, 10:04
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Important note about the Debugging task is to ensure that you Undeploy your Downloaded code prior to attempting to 'Run Kernel Task'.
The reason is that the Download option copies a file to the file system on the cRIO, then that file executes when you restart the robot. The 'Run Kernel Task' option copies EVERYTHING over to the robot, but in a different place and starts running it. So, if you've got downloaded code running and you try to debug you will get, at best, inconsistent results.
So, prior to the 'Run Kernel Task...' make sure you goto the FIRST menu and select Undeploy.
D. Sean Kelly
Team #499
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 13-01-2008 15:06
How do I know if I'm overloading the RC program? PhilBot Programming 8 03-03-2007 20:23
How do you program the Photoswitch nekng Programming 2 27-11-2006 13:41
how to teach the newbies to program? BorisTheBlade Programming 6 24-10-2005 18:56
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
