Re: the size of the pipe on the goals
Posted by Erin at 2/3/2001 2:11 PM EST
Other on team #65, Huskie Brigade, from Pontiac Northern High School and GM Powertrain. In Reply to: the size of the pipe on the goals Posted by Brian on 2/3/2001 1:33 PM EST: The PVC pipe on the goals is a size that happens to be specified in the manual. just check there for all dimensions...and if you dont have a manual, then your in trouble good luck with the goals...those things are fun to play with ![]() erin |
| What size monitor do you use? | Elgin Clock | IT / Communications | 30 | 10-03-2004 16:53 |
| Curie Division Robots information... (not complete) | archiver | 2001 | 3 | 24-06-2002 03:13 |
| Stategy Debate: Goals Horizontal vs Goals Vertical | archiver | 2001 | 2 | 23-06-2002 23:32 |
| WOW ! | Mike Schroeder | General Forum | 12 | 12-03-2002 21:32 |
| goals and balls | Strath | General Forum | 0 | 14-02-2002 22:34 |
