Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Unread 29-12-2008, 13:48
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Flash Drive Error
Hi!
Hi, I have bought a new Sandisk USB 2.0 Flash Drive. It has been working fine until last night when I plugged it into my laptop.
When I double clicked the drive, a pop-up shows "Access is denied". I found it very strange. So I right click it and see whether it is something wrong with security reason. However, after I have made it shared and set permissions for everyone to full control it, the problem still persists. I've also reformatted it multiple times with FAT32, and NTFS using both XP & Vista. A screenshot of the error message.
I'm not sure what to do, and any advice would be greatly appreciated. Thank You.
AIM Robotics
2008 NASA/VCU Regional: Rockwell Automation Innovation in Control Award
Unread 29-12-2008, 13:55
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: Flash Drive Error
Do other drives return the same error or just this one?
This thread suggests some possible causes and solutions.
Unread 29-12-2008, 13:58
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
What kind of laptop is it?
if it is a mac, i had the same problem, if you set a password for your jumpdrive on a PC, and then plug it into a MAC, it will deny you access. to solve, use a PC to disable the password, and then you should be all set.
also another note, if it comes with U3 DELETE IT, i dont know if that could cause the problem, but it SUCKS.
Unread 29-12-2008, 14:06
aksimhal's Avatar
AKA: Anish
I looked at the link, and used the MMC to reset permissions - didn't help at all.
I am using a Dell XP Professional, and have tried it on HP XP Media Center desktop as well. I've reformatted the drive using MMC, right clicking on the drive, and the HP USB Disk Format Tool. Also, U3 has been removed from the Flash Drive.
Thank You
AIM Robotics
Unread 29-12-2008, 14:12
Blue Shirt
FRC #0237
I have become a fan of clicking of the drive icon in the tray and doing the "Safely Remove Hardware" process. I have never bricked a flash drive, but that may be what you did.
Unread 29-12-2008, 14:14
aksimhal's Avatar
AKA: Anish
Ok, that might be the problem - I generally don't do the "Safely Remove Hardware" process. So is there anything that can be done, or do I have to throw my flash drive away and get a new one?
AIM Robotics
Unread 29-12-2008, 15:08
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Failure to use the "safely remove" functionality shouldn't brick a flash drive(all it does to causes the computer to sync the delayed-write buffer). And reformatting in theory would correct any problem that came from this anyway...
Does the flash drive work on other computers?(and do other flash drives work on that computer?)
Unread 30-12-2008, 12:40
I have to ask if you have loaded any software that talks to your USB ports? Flash drives get finicky with USB settings. You might try the old cold boot to clear any problems with the USB drivers and ports in case you haven't yet.
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
flash drive tseres IT / Communications 20 13-06-2007 16:05
How would I interface a flash drive to the RC? JBotAlan Technical Discussion 42 31-01-2007 15:24
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
MPLAB on USB flash drive ultramrw21 Programming 3 25-01-2005 21:20
