Problems undeploying a program from the cRIO
Hello,
Someone on my team downloaded a program to our cRIO (flashed it so that it runs on startup). I am trying to debug another program, but I can't download it until the original program is "undeployed" (FIRST -> Undeploy in Workbench). However, undeploying it gives the error: Unable to connect to robot using IP: 10.0.0.2:21 I can connect to the cRIO fine otherwise, in the "Remote Systems" pane in Workbench. Of course, the above IP address is the wrong one for the cRIO: it should be 10.15.40.2:21 instead (team 1540). Would anyone happen to know what is wrong? I would really appreciate any help. -Kevin |
Re: Problems undeploying a program from the cRIO
In the Windriver preferences, under FIRST Downloaded Preferences, set your team number.
Thanks!
| cRIO Not Running Program | railerobotics | NI LabVIEW | 5 | 18-01-2009 08:48 |
| how to transfer the program to the crio? | beefy1 | Programming | 5 | 04-01-2009 10:04 |
| 24v Power Conector to from the PDB to the cRIO | mcf747 | Electrical | 14 | 01-12-2008 19:19 |
| How Do I Program My RC To Spot One wheel From Going faster than the other | Kyle1010 | Programming | 5 | 12-01-2003 15:30 |
