Go to Post Can you restate your observation in a manner that reconciles with physics? - Madison [more]
Unread 29-12-2008, 14:42
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Problems undeploying a program from the cRIO
Hello,
Someone on my team downloaded a program to our cRIO (flashed it so that it runs on startup). I am trying to debug another program, but I can't download it until the original program is "undeployed" (FIRST -> Undeploy in Workbench). However, undeploying it gives the error:
Unable to connect to robot using IP: 10.0.0.2:21
I can connect to the cRIO fine otherwise, in the "Remote Systems" pane in Workbench. Of course, the above IP address is the wrong one for the cRIO: it should be 10.15.40.2:21 instead (team 1540).
Would anyone happen to know what is wrong? I would really appreciate any help.
-Kevin
Unread 29-12-2008, 15:31
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Problems undeploying a program from the cRIO
In the Windriver preferences, under FIRST Downloaded Preferences, set your team number.
Unread 29-12-2008, 16:21
FRC #1540
Thanks!
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
how to transfer the program to the crio? beefy1 Programming 5 04-01-2009 10:04
24v Power Conector to from the PDB to the cRIO mcf747 Electrical 14 01-12-2008 19:19
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
