Go to Post Well, it's officially that part of the offseason where we all lose our minds again. - Whippet [more]
Unread 29-12-2008, 14:18
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
Unhappy New Control System Update Problems
Hi,
We set up the benchtop test and it worked fine. We figured the wireless setup would not work until we set the team number, which required an update. So, after updating it, we decided to try the wired test again just in case. Well, guess what: it didn't work. When we enable it, the Jaguars continue to blink yellow and nothing responds. We have tried power cycling both the cRio and the DS, to no avail. Has anyone else had this problem? I tried searching for it, but found nothing. Today was our day to set up the controller before build season, so it would be great if we could get it working.
Thanks,
Team 811
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 29-12-2008, 14:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: New Control System Update Problems
Did you update both the cRIO and the DS?
Unread 29-12-2008, 15:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Did you change the team number on both the cRio and the DS?
Eric Haskins KC9JVH
Unread 29-12-2008, 23:04
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
That was precisely it: we had not changed the IP on the cRio as we had not updated the cRio yet. It turned out that to update it we needed to install LabView, something we had attempted to avoid due to the long time and large disk space requirements and the fact that we are not planning on using it. Ah well, after we installed LabView, we updated the cRio and set the IP address and all went well. We even have a working driverbot now. Maybe later I'll make a new topic with a link to a vid.
New Control System Problems ExarKun666 Technical Discussion 13 23-12-2008 16:29
New Control System - Wireless Problems Ashwin FRC Control System 13 11-12-2008 10:38
**FIRST EMAIL**/Control System Software Update Reminder Mark McLeod FIRST E-Mail Blast Archive 13 30-11-2008 21:05
Important IFI Control System Update Kevin Watson Control System 5 25-02-2004 23:31
Control system update RebAl Electrical 1 26-12-2002 22:36
