Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 29-12-2008, 13:17
quizbiz quizbiz is offline
FTC #0273
quizbiz is an unknown quantity at this point
Labview Servos
I can get to one extreme but not the other extreme on the other side. I have values between 0 and 254. It won't let me put in negative values which I tried to do.
Also can someone explain the Scale Servo VI to me please? I have a feeling I should be using it but am unsure what it does or how to use it to effect the servo performance.
Thanks for your help.
Unread 29-12-2008, 21:45
Re: Labview Servos
I think that the integer scaled VI for servos tends to be in degrees. The servo I've used it on went from 0 to 169 or 170. More expensive servos go to 200 degrees or more. I didn't use the scale VI, and I don't have the VIs in front of me, but I suspect they are to scale between the int degrees and the 0 to 1 scale common to the other APIs such as joysticks.
Greg McKaskle
Unread 29-12-2008, 22:28
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: Labview Servos
What we've been able to determine is that the servo's, unlike the jaguar's, range from 0 to 1 (default) with .5 being their center position. We also found that they wouldn't work at all without the 6V jumper installed. FYI, the jaguar range is from -1 to 1 (default).
Unread 30-12-2008, 09:16
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Labview Servos
Without that jumper installed in the Digital Sidecar (aka DSC), servos won't have any power. The jumper should only be installed in positions that are driving servos since speed controllers such as Victors and Jaguars don't need to have power supplied via the 3-pin PWM cable (they're entirely powered by the big V+/V- terminals).
In fact, some speed controllers output a 5V (or so) power supply on their middle pin for powering external electronics. Such speed controllers would back-feed the DSC if the 6V power jumper was installed (generally not a good thing).
Russ
Unread 09-01-2009, 00:30
brianc217's Avatar
brianc217 brianc217 is offline
None #1153
brianc217 is an unknown quantity at this point
Re: Labview Servos
I think this will help my team a lot. We couldn't get the servos to work AT ALL but it looks like the problem is that 6V jumper.
Is there a manual somewhere that has all those little tips and tricks like that so we don't have to spend days trying to get a simple servo to work.
I will blame hardware as usual. haha. thanks.
Unread 09-01-2009, 08:48
Re: Labview Servos
Originally Posted by brianc217 View Post
...Is there a manual somewhere...
http://usfirst.org/frccontrolsystem
What you're specifically asking about is Chapter 3 Component Data Sheets. Section 3.5 is all about the Digital Sidecar.
Labview NXT Servos quizbiz National Instruments LabVIEW and Data Acquisition 1 30-12-2008 14:42
servos Thadanator Motors 13 04-05-2005 16:57
servos savage Technical Discussion 5 09-04-2005 20:52
servos AlphaOmega870 General Forum 1 21-01-2004 17:37
Servos... Katie Reynolds Motors 8 14-01-2002 08:08
