Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
  #46   Spotlight this post!
Unread 11-06-2008, 18:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: The 2009 Control System Q&A Thread
Originally Posted by Bomberofdoom View Post
Q: Which module is the PWM output one?
The PWM signals come out of the 9403. There is a break-out board that attaches to it that will provide the needed buffering.
Q2: If we don't have the new distribution block, can we use/ alternate the old electronic system and connect the CRio through it to the current motors?
The cRIO controller needs 24V to run. The new power board has a power supply on it to provide that 24V even when the battery voltage droops. With the exception of needing 24V, the rest of the old electrical system can be used to power motors. If for instance you were doing a bench test and powered the cRIO with a 24V power supply plugged into the wall and the motors were powered through the old breaker panel, it would work just fine.
Cheers!
-Joe
  #47   Spotlight this post!
Unread 16-06-2008, 15:24
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Joe,
On The FIRST Community website, the tutorial: "NI CompactRIO Project and Building Source Distributions" refers to adding Targets. As I read it, this requires LabView Real-Time or one its sister programs. Will we be able to download a module to our existing LV 8.5 to enable us to do this?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #48   Spotlight this post!
Unread 17-06-2008, 00:21
Originally Posted by Jon236 View Post
Joe,
You are correct. You will need LabVIEW RT if you choose to program the controller in LabVIEW. I believe the LabVIEW RT module will come on a DVD with the rest of the software needed. I don't know that it will be available as a download.
-Joe
  #49   Spotlight this post!
Unread 30-06-2008, 20:42
Jwxie's Avatar
Jwxie Jwxie is offline
3017 Chife Captain
AKA: John Wong
FRC #3017 (Project Genesis)
Jwxie is on a distinguished road
Send a message via ICQ to Jwxie Send a message via AIM to Jwxie Send a message via MSN to Jwxie
great
i am reading this
it will help my team to start
Build a Dream, Comes a Team, will make everything more than just a dream.
Project Genesis
Team 3017
Rookies 2009 FRC@ NYC
  #50   Spotlight this post!
Unread 14-12-2008, 09:47
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Drivers station question
Does anyone know if it is possible to display data using the onboard LCD on the drivers station? I could not find anything in the C++ libs or docs. Is it possible using the NI interface? It would be nice if we could use the LCD to provide feedback.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #51   Spotlight this post!
Unread 14-12-2008, 09:50
Re: Drivers station question
See section 3.1.8 of the manual.
  #52   Spotlight this post!
Unread 14-12-2008, 11:47
Thanks. Question about these issues listed below. Have they happened during any of your testing?
• Occasionally, communication will lag by about 2 seconds. The workaround is to unplug any Ethernet cable for a second, then plug it back in.
I assume this could also happen during a match.
• Occasionally, communication will stop between the DS and the cRIO. One way to notice this the robot will stay disabled when you enable. The battery voltage on the DS display will also not update. The workaround is to unplug power to the DS and then let it reboot.
Same statement as above. With the documented 55 second max boot time this would pretty much disable the robot for the majority of the match.
Mike Copioli
  #53   Spotlight this post!
Unread 14-12-2008, 12:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I'm pretty sure they are going to take care of those issues before competition season comes around. If it doesn't get fixed, FIRST will quarter whoever is responsible.
  #54   Spotlight this post!
Unread 30-12-2008, 00:10
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Q: As stated in the 2009 Control System Manual section 3.1.1, the Driver Station runs 'Linux'. As Linux (probably in addition to other software on the driver station) is governed by at least the GPL v2 (particularly section 3), and as US FIRST is distributing the software, where may I download the source code for the GPL'd products utilized by and distributed for the Driver Station?
  #55   Spotlight this post!
Unread 30-12-2008, 03:03
Samuel H. Samuel H. is offline
Rookie Year: 1000
Samuel H. has a spectacular aura aboutSamuel H. has a spectacular aura about
Hello codes02,
Thank you for asking, unfortunately, this site might not be the best place to bring this (possible) omission up. I would recommend emailing frcteams@usfirst.org, FIRST's contact email for matters relating to the FIRST Robotics Competition, to get a response from those who are better able to fix any oversight.
Thanks,
Sam
  #56   Spotlight this post!
Unread 09-01-2009, 16:18
mike75 mike75 is offline
FRC #0075
mike75 is an unknown quantity at this point
>> Driver Station User I/O Connector???
Any ideas on what connector(s) to use on the 3x20 User I/O pin set on the driver station? I've been looking for days and can't find any good options. Thanks!
  #57   Spotlight this post!
Unread 09-01-2009, 16:24
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Re: >> Driver Station User I/O Connector???
1) When we try and update the CompactRIO Imaging Tool, it comes up with a message saying:
"Unable to assign an IP address for the CompactRIO device. Ensure the IP Reset switch on the CompactRIO device is turned off."
Tried with both configurations.
2) Also, what are the purposes of all the switches next to the IP Reset Switch?
Thank you!
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
  #58   Spotlight this post!
Unread 09-01-2009, 16:58
Standard RC servo connectors work great. I've bought them from http://www.hansenhobbies.com/ in the past.
  #59   Spotlight this post!
Unread 11-01-2009, 04:32
AKA: Cody Schafer
Originally Posted by Samuel H. View Post
Hello codes02,
Thanks,
Sam
In case anyone was wondering, I sent an email to FIRST as soon as I read Samuel's post (thank you for the prompt response).
As it has been 11 days, and I have received no reply, I sent resent the same message to them a few minutes ago.
  #60   Spotlight this post!
Unread 11-01-2009, 10:43
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Thank you!
I'm having the same problem.
Before it asked you "Ensure the IP Reset switch on the CompactRIO device is turned off" did it say to turn safe mode on?
Behind the Design 2009 AndyB General Forum 31 16-06-2008 13:59
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
The Access Points on the 2009 Control System Shadow503 Rumor Mill 10 28-04-2008 23:22
Championship Event in Atlanta for 2007 = Confirmed (possibly 2008 & 2009 too) Elgin Clock Championship Event 18 24-08-2005 00:37
pic: The Bobcats 2001 & 2003 & Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
