Go to Post Just call me conservative. - dlavery [more]
Unread 30-12-2008, 09:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Can I control a victor/jaguar with an RC receiver
Can a victor or jaguar be controlled by the pwm off of a standard radio control receiver?
Thanks
Bruce
Unread 30-12-2008, 09:52
Re: Can I control a victor/jaguar with an RC receiver
I believe so. The Jaguar might need to be recalibrated, since it has a different input range and rate (its input optimized for use with the 2009 control system).
Give it a shot and tell us how it goes.
Unread 30-12-2008, 10:36
FRC Key Volunteer Trainer
AKA: CrazyNate
For the Victors, you need the PWM signal driver listed here (http://ifirobotics.com/victor-884-sp...r-robots.shtml) to have them work with any non-IFI control system. As for the Jaguars, I don't know...
Nate Smith
nsmith@smythsoft.com
Unread 30-12-2008, 10:50
Doh! Thanks for the reminder.
The signal input stage of the Victor requires a little bit more current than a standard hobby transceiver will give, and therefore needs an inline amplifier. The Jaguar's signal input stage is several times less demanding current wise, and (probably) doesn't. I'll rely on Luminary to give the definitive answer.
The Digital Sidecar fills a similar role. The NI module the DSC plugs into has enough drive strength for servos and Jaguars, but needs a little help if it is to reliably drive several Victors.
Jaguar and Victor Flashing lights? programmr FRC Control System 24 17-12-2008 15:44
Using vex micro controller with hobby shop receiver? kajeevan Programming 2 28-11-2008 02:53
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
Receiver to control unit connection Bob16 Robotics Education and Curriculum 4 27-10-2004 09:20
Victor control with Edurobot?? Bob Steele Motors 4 19-02-2003 12:48
