Go to Post Did you inform McMaster Carr that up to 3000 FRC teams would all be attempting to acquire a very specific spring ASAP all on the same weekend? - cgmv123 [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
  #226   Spotlight this post!
Unread 05-01-2008, 03:19
Re: **FIRST EMAIL**/FRC Game Hint #3
Originally Posted by dlavery View Post
psssh. Sleep is for the weak.
-dave
Wise words from an insomniac master?
  #227   Spotlight this post!
Unread 05-01-2008, 03:26
Optimizer Optimizer is offline
AKA: Frank Stanley
FRC #1507 (Warlocks)
Optimizer is a jewel in the roughOptimizer is a jewel in the roughOptimizer is a jewel in the roughOptimizer is a jewel in the rough
-dave
Point taken!
  #228   Spotlight this post!
Unread 05-01-2008, 03:39
EddieMcD EddieMcD is offline
EddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud ofEddieMcD has much to be proud of
Say Dave, isn't it past your bedtime? Big day tomorrow, and whatnot?
Anyhow, I may as well put in my annual "<12 hours before kickoff" game prediction.
And there's really only one thing all three clues have been telling us. The abnormally square piece of paper in the first game hint, the coordinates pointing us to a "globe cafe" in the second hint, tetras in the third clue: whatever you guys are doing will involve the first logo in some way. Whether or not you'll be manipulating cubes, tetrahedrons, & spheres all at once into a single goal for differing point values/multipliers (which BTW, has always figured into my "dream game" in some fashion), or whether it'll be some variety of stacking or putting different-shaped objects into other-shaped goals, somehow, my prediction is that something square-ish, something circle-ish, & something triangular will be involved. And all the clues link up too (Copely Square, and the FIRST Corps of Cadets Veterans [hurdling tetras] located in said square)! And since this is FIRST we're talking about, there's probably going to be a choice to make at the end between continuing what you're doing, or scoring secondary points. Say, what if the end game is another autonomous period where that IR receiver helps you perform your last point scoring maneuvers...
Finally since I can, I'll step into WATER GAME!!1! territory for just a second: what good is a globe without it being 70% water? I kid, of course.
  #229   Spotlight this post!
Unread 05-01-2008, 03:42
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Dave must have just finished the game animation, and decided to take a breather from animating
  #230   Spotlight this post!
Unread 05-01-2008, 04:15
AKA: Frank Stanley
First, I should correct myself - Kick-off is today!
Then I just wanted to take my last shot at this. I took to heart Dave's somewhat lengthy (but worthwhile) discussion on the importance of knowing what precision you have, as well as what precision you need.
Revisiting the "where, exactly, is this spot?" question, I recalled that the first people who located the spot (on Google, I think) varied the input and got the same result. This means that has a significant (if undetermined) inaccuracy.
I figured where the spot should be independently, using topo map images, and had estimated that the answer might be good to about 30FT. The closest thing to that spot, BTW, is a statue of Philips Brooks (not Copely), which is along the north side of Trinity Church. Given the unknown accuracy of Google, I'm going with this spot now.
My first estimate was that the bearing headed toward the burger joints from there, but looking more carefully at it, it looks more like it's really across from a subway stop. If I still thought it was looking at the Burger King, I would confidently conclude that the clue meant "Stack Attack" (meaning that elements of that previous game would return this time).
All I can do is speculate that my errors are a bit worse than I thought, and that #2 really does just mean "Stack Attack" (plus a hint of better floating-point computing this time).
Hint #1 was probably just so we wouldn't freak out about this new equipment that seems complicated at first, but isn't really such a big deal after you sit down and look at it. They must really want to make sure we succeed at employing it.
#3 just seems to be another reference to aspects of previous games being revisited (with a new twist, I'm sure). So far we have a combo of Stack Attack (the Burger King campaign), Triple Play (the tetras), and Aim High (something airborne - "hurdling").
Sounds like fun!
  #231   Spotlight this post!
Unread 05-01-2008, 09:42
organman42's Avatar
organman42 organman42 is offline
AKA: Jeff
FRC #1073 (The Force Team)
organman42 is an unknown quantity at this point
-dave
only during build season
"I have a different vision of leadership. A leadership is someone who brings people together."
  #232   Spotlight this post!
Unread 05-01-2008, 12:03
Nin_estarSaerah's Avatar
Nin_estarSaerah Nin_estarSaerah is offline
That's Madam President, actually
AKA: Sarah
FRC #1539 (Blue Eagle Robotics)
Nin_estarSaerah is just really niceNin_estarSaerah is just really niceNin_estarSaerah is just really niceNin_estarSaerah is just really niceNin_estarSaerah is just really nice
the encryption key is an anagram of vet hurdling first tetra
  #233   Spotlight this post!
Unread 05-01-2008, 12:09
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
It is? Hmm even if you figured that out though you wouldn't have the CAPS and the punctuation.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #234   Spotlight this post!
Unread 05-01-2008, 12:14
AKA: Sarah
yeah i know, because i tried about 20 anagrams, including drivestraitturnleft but yeah...punctuation was the problem
  #235   Spotlight this post!
Unread 05-01-2008, 13:34
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
The anagram, spelled correctly, is
drive straight turn left
It corresponds letter for letter with the words in the clue. Word puzzles don't generally rely on capitalization and punctuation, so as far as I can tell, it's 100 percent accurate.
Karen Husmann
Ex Robo-widow
  #236   Spotlight this post!
Unread 05-01-2008, 13:51
AKA: Sarah
pardon me, my spelling is generally bad when i'm typing too fast...
word puzzles don't rely much on punctuation and capitalization, but passwords do!
  #237   Spotlight this post!
Unread 09-01-2008, 12:38
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Password or not, "drive straight turn left" does describe what the robots do in this year's game.
Zan Hecht
  #238   Spotlight this post!
Unread 30-12-2008, 17:11
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Well, whatever the game ends up being, I sure hope it involves the IR sensor and the IP camera intensively. I got accepted to MSOE for my work last year (AS A PROGRAMMER) on my team's IR board, from wiring to mounting to programming to interface design. I would love to have that kind of challenge again, especially if it is made a core part of gameplay and more teams feel obligated to work with it.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
  #239   Spotlight this post!
Unread 30-12-2008, 17:18
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Someone should probably edit the title of this to clarify that this is for the 2008 game, I know I jumped when I thought "How did a game hint and 200+ replies get generated without me noticing?"
  #240   Spotlight this post!
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Um ya, this was last years hint, just an FYI
**FIRST EMAIL**/FRC Game Hint #2 Gamer930 FIRST E-Mail Blast Archive 699 04-09-2008 17:29
**FIRST EMAIL**/FRC Game Hint kramarczyk FIRST E-Mail Blast Archive 8 16-12-2007 22:00
2007 Official FRC Game Hint / Email Blast jacob07 Rumor Mill 822 03-07-2007 16:27
