Go to Post Yeah refs are trained to not have a sense of humor about things like that. - Koko Ed [more]
Unread 30-12-2008, 21:26
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Robot suspension
Unread 30-12-2008, 21:27
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: pic: Robot suspension
Novel suspension
One question: Why toughboxes on one side and different transmissions on the other side?
Edit: Dang it, I should've looked at the other picture before posting. Sorry!
"One side we used bain bot gear boxes and on this side we used kit gear boxes. This is just a proto type to see how different gear boxes would work."
Unread 30-12-2008, 22:20
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Originally Posted by tdlrali View Post
Novel suspension
those arent toughboxes, they are the kit transmissions from 2006(I think)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 30-12-2008, 22:23
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Yes 2006, we just took those apart the other day to grease them up to use with the new control system!
Unread 30-12-2008, 22:27
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
I am very impressed with this design. It's a beautiful hybrid of a 6wd and a mechanum, with a very nice suspension.
Which end would you use as the front? The end with the moving wheels would be preferable for weight, but the other side would have an advantage from supporting and control standpoints.
Also, I'm almost afraid to ask, but how much does this weigh in?
Unread 31-12-2008, 15:14
joeweber's Avatar
Coach team 1322
The weight of the drive unit with the bane bot gear boxes was 30 lbs. The other side we did not check. If we used Andy Mark wheels and did a direct drive to the wheels (no helical gears) and placed some hole in the frame we should be able to get the weight down less than 25 lbs. with a total of 50 lbs for both drive units. The only other frame we would need is for the arm attachment.
More Pictures http://www.team1322.org/ideas.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 01-01-2009, 23:30
joeweber's Avatar
Coach team 1322
Just completed a video
http://www.youtube.com/watch?v=xby0S...e=channel_page
Unread 01-01-2009, 23:40
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
How well does it slide from left to right? Does the omni-wheel cause enough drag to not justify the mechanum wheels? Are you even using it as a left to right slide robt or are those just wheels that you had?
Thanks so much
Unread 01-01-2009, 23:55
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Cool video! That's a very clever drivetrain concept, and I'm glad to see you got it working. It looks like a really fun project, although it may be difficult to implement for a FIRST robot (mostly because of the mechanism and bumper mounting... but I'm sure you guys could think of something ). I'd love to see it used in competition.
Can it go up the ramp fully sideways, or does it start to slip?
Unread 02-01-2009, 16:50
joeweber's Avatar
Coach team 1322
We have been driving it quit a bit and it goes sideways and angle wise great. If we do use it for competition we would use segmented bumper for each of the moving drives. We originally were going to attach them to the rods that supported the main part of the robot but the stationary bumpers might hit the ramp as it goes up and over.
Unread 15-01-2010, 14:31
MaiPrettyPwny MaiPrettyPwny is offline
If it doesn't fit, get a hammer.
FRC #0818 (Steel Armadillos)
MaiPrettyPwny is an unknown quantity at this point
Could you tell me if I'm looking at this right?
It looks like, to me, that the two wheel assemblies are only connected to the central frame in three points. One on either side of the frame near the rear wheels (the white tube, yes?), and the other on the parallelogram in the front.
If this is true, when that parallelogram "flexes," doesn't it pull the two front wheels in towards each other?
Unread 15-01-2010, 20:32
joeweber's Avatar
Coach team 1322
Yes you are correct. For the test robot it did bring the front wheels closer. With this years robot we are not useing the three points, we will use four but they will be above the robot drives.
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
Robot Adaptive Suspension Andrew Blair Technical Discussion 13 09-09-2005 12:02
