Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 30-12-2008, 23:54
Arcre Arcre is offline
jp
AKA: Jorge
FRC #2504
Arcre is an unknown quantity at this point
Electrical Problem
Our Team spent almost the whole day trying fix our electrical system. The problem was the jaguars fan's wasn't moving and when we tried to move the joystick and the cim motor wasn't moving too. The link below shows our electrical system.
http://drop.io/FRC2504
Unread 31-12-2008, 00:03
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Electrical Problem
from Control System Manual, Section 2, Page 4:
Connect the Digital Sidecar to the NI 9403 module installed in slot 4 of the cRIO with the supplied DB-37 cable.
As indicated by picture dscn0368, your Digital Sidecar is connected to the NI9403 in slot 6. This is not the default configuration, and will not work with the bench test or the default code. Unless you have written custom code, move the DB-37 cable to the module in slot 4.
Unread 31-12-2008, 00:19
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
well looking at your pics I see a couple things. First your pwm wires, black should be to the inside on the digital sidecar. Second, on the jaguars black pwm wire should be towards the inside. Third, you only need to fuse where motors are connected to red wagos (see the lighting bolts on the distribution panel. they alternated sides.)
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 31-12-2008, 00:30
jp
AKA: Jorge
FRC #2504
Thanks! We will try that tomorrow at 6 in the mourning so early. I have another question, we have download a new program to the cRIO and updated the firmware for the DS would that be a problem to controlling the motor with the joystick?
Unread 31-12-2008, 00:43
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If you have updated the firmware on both the cRIO and the DS they should be able to communicate and the joysticks should control the motors attached to PWM channels 1 and 2 with the default code.
If you are actually saying that you downloaded a new program to the cRio (through either Labview or Windriver and not the cRIO Image Tool) then the program will have to work correctly for the joysticks to control the motors and the cRIO firmware will have to be updated (if that has not been done already).
Unread 31-12-2008, 09:34
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
if i where you , i would organize everthing a little bit better than that, it helps to quickly look over the system for problems! it helps for us!
Unread 31-12-2008, 10:11
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
According to the above datasheets for the Digital Sidecar (aka DSC), chapter 3.5.1.2 has all ground terminals for the PWM outputs, relay outputs and GPIO on the outer edge. The black wires should be on the outer perimeter of the DSC.
Russ
Unread 31-12-2008, 19:52
jp
AKA: Jorge
FRC #2504
We have changed our jaguar to a victor, and connect the right way. According to you guys replies. The cim motor just move without the joystick control nor the autonomous. I have no idea how to fix this and would the labview programming cause this problem or the driver station?
Unread 31-12-2008, 22:21
jp
AKA: Jorge
FRC #2504
We spend the whole day working on it, and found the solution! The pwm wire wasn't good, and we change the jaguar because the other one is broken.
Beginner Electrical DavidB Electrical 10 09-12-2008 21:25
[OCCRA]: Robot Controller (electrical box) problem Kettering OCCRA Q&A 1 20-10-2008 09:03
Electrical randomperson FIRST-related Organizations 0 31-05-2003 23:26
Electrical Components? Miles General Forum 5 10-01-2003 08:12
Electrical Mike o. Electrical 3 10-02-2002 21:51
