Go to Post FIRST opened a door and I walked through it. - Erin Rapacki [more]
Unread 31-12-2008, 10:21
finman's Avatar
finman finman is offline
Programmer
AKA: Chris Finley
FRC #0888 (Robotiators)
finman is an unknown quantity at this point
No response from speed controllers
after installing all the updates and putting the newest cRIO image on the cRIO, our test robot works perfectly. as soon as i download the default labview code, i get no response from the speed controllers. where should i look to fix this?
"Red goes to black, right guys?" ~Mike Mascaro: Our Fearless Leader
Unread 31-12-2008, 10:45
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: No response from speed controllers
You should check all the settings in the Basic Robot Main.vi (if you are using the basic setup). Maybe the USB ports are off, or perhaps it's not talking to the correct jaguar, etc.
Good luck,
keehun
Unread 31-12-2008, 11:03
finman's Avatar
Programmer
AKA: Chris Finley
i believe that the problem is that we are not successfully deploying the code; it works while we have the program running on the computer, but as soon as the computer is disconnected, it won't run.
Unread 31-12-2008, 11:41
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I had the exact same problem. The root cause it that the correct DIO is not assigned by default.
Open the "Drive Open 2 motor" VI on the left side of the motion loop. Switch to the block diagram and add the slot number of the DIO you are using to the two "Motor Open Jaguar" vi's, the default would be "Slot 4".
Unread 31-12-2008, 12:28
keehun's Avatar
Team Captain
AKA: Keehun Nam
You can not disconnect the computer to the robot if you want the cRio program to run. I'm not sure what the cause is and I don't know how it'll be at the competition.
Unread 31-12-2008, 12:58
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Are you actually deploying the code to the cRIO (burning the image to the system and telling it to run on startup) or are you just flashing it to the cRIO (what happens by default)?
One will work with the computer (flashing) and one will run without any knowledge of a computer (burning/deploying).
-Tanner
Unread 31-12-2008, 16:16
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
There are two main ways to get your code on the cRIO using Labview. One way loads the program into the cRio's RAM and requires a connection be maintained with the host computer. The other way deploys the program into the cRio's flash memory and does not allow for a computer connection for front-panel debugging (the computer can still be connected for the dashboard).
To read more about these two methods and how to perform each see Chapter 5 of the FRC Programming Guide specifically pages 5-6 and 5-7.
Speed controllers.... Denman Technical Discussion 14 07-10-2004 15:19
speed controllers archiver 2000 5 24-06-2002 00:19
Speed Controllers archiver 2000 2 24-06-2002 00:08
Speed Controllers archiver 2000 1 23-06-2002 23:01
Speed Controllers... Tom Schindler Technical Discussion 4 13-12-2001 17:26
