Go to Post If you have time at a competition, stop and thank some of the people wearing the crew shirts. They are working very hard to make sure the competition goes as smoothly as possible. - Greg Young [more]
Unread 01-01-2009, 13:38
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Default Code?
I set up the Crio and got it to run a motor. What code is on the Crio by default? How do I open it in wind river? thanks.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 01-01-2009, 13:45
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: Default Code?
in windriver
go to file > new > example... > Downloadable VXworks kernel module > Simplerobot code (or Itterative robot)
Unread 01-01-2009, 13:48
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Re: Default Code?
Yeah, I tried that but wind river just freezes up. I'm running vista.
Unread 01-01-2009, 14:11
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Re: Default Code?
as am i.
well thats basically your only option.
try running it as an administrator (you'll need to do that anyway actually)
if that doesn't work, try re-installing it...
not sure what else to tell ya.
Unread 01-01-2009, 14:51
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
Re: Default Code?
Ok, I got it to work. It must have been something with my computer because after rebooting it, it now works. Thanks for the help.
Unread 09-01-2009, 00:39
DonF DonF is offline
FRC #1277
DonF is an unknown quantity at this point
Re: Default Code?
I'm having an issue with a Wind River installation on an Vista X64 machine. The envionment seems to work but the default code does not show up although it is in the demo directory. I managed to compare with a XP 32 bit machine and I can see the FRC code on that machine when I select new examples. The default code is in the demo directory on the x64 machine but selecting new-> examples only shows 3 samples, Hello, Complex demonstration and Yacc.
I also had to reinstall Wind River becasue I originally put in the F: directory. I usually put large non core programs on another drive so c: does not fill up with junk so I can back it up easy. Labview is working off of F: and MPLAB worked of F: last year on the same x64 machine. .... sigh
Don
Unread 09-01-2009, 23:23
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
Re: Default Code?
It's a good idea, but I'm a bit too lazy to do it myself
WindRiver is based off of Eclipse, and I know that Eclipse works anywhere you copy it. WindRiver is apparently not as well designed, and so far it seems to have some annoying interface bugs. As for compatibility, it works fine on my Vista x32 laptop.
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
