Go to Post It does it automagically. - David Kelly [more]
Unread 02-01-2009, 13:18
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Straberrie will become famous soon enough
Servos??? *C++*
Hey all,
Servo panservo(1);
float servoRange = panservo.GetMaxAngle() - panservo.GetMinAngle();
for(float angle = panservo.GetMinAngle();
	angle < panservo.GetMaxAngle();
	angle += servoRange / 10.0)
	panservo.SetAngle(angle);
	Wait(.1);
We have a servo plugged into PWM channel 1 on the primary sidecar module, and have this code in the autonomous function but the servo ceases to move. The code is mostly directly out of the programming guide, except for changing the channel number to match our setup. Any ideas/suggestions?
Thanks!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 02-01-2009, 13:28
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Thumbs up Re: Servos??? *C++*
Do you have a jumper on the digital sidecar next to the connector to which the servo is connected?
Unread 02-01-2009, 14:15
Straberrie's Avatar
The Plague
AKA: Rebecca
Re: Servos??? *C++*
It worked!! TY!!!
Servos? PrincessJae Motors 15 26-01-2008 01:33
servos savage Technical Discussion 5 09-04-2005 20:52
servos AlphaOmega870 General Forum 1 21-01-2004 17:37
Servos... Katie Reynolds Motors 8 14-01-2002 08:08
