Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
Unread 02-01-2009, 12:29
John Timmerman John Timmerman is offline
FRC #2188 (Critical Mass)
John Timmerman is an unknown quantity at this point
Send a message via Yahoo to John Timmerman
HELP!! With the OTB Firmware
Please tell me there is a place to download the original OTB (out of the box) Firmware for the new control system!?!? one of our team mates updated the controller before we could bench test it, and now when we try to program it, nothing works, we need the bench test to find out whats wrong exactly. If you can give me a place to download the original Firmware that would be GREAT! and greatly appreciated! Thank You
John Timmerman
Team 2188
Unread 02-01-2009, 13:19
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: HELP!! With the OTB Firmware
The OTB firmware is not available.
Make sure you upgrade BOTH your cRIO and your DS, and set the team numbers accordingly on both. It should work then - if not, check out the 20 other threads about this topic.
FRC CompactRIO firmware upgrade help mole Programming 8 17-01-2009 18:46
Help with updating firmware on Driver Station urg8rb8 FRC Control System 3 28-12-2008 02:53
Can i still benchtest without OTB version? programmr FRC Control System 7 16-12-2008 20:52
promblem with RCX firmware and BricxCommandCenter (NQC) remy FIRST Lego League 7 25-01-2006 07:39
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
