Go to Post Once you know where you want to go, you can decide how you want to get there. - sciguy125 [more]
Unread 02-01-2009, 14:13
Re: Power Distribution - Low current breakers or fuses?
Originally Posted by Russ Beavis View Post
http://www.snapaction.net/pdf/vb3.pdf
Assuming that the 2009 game and robot rules allow them, wouldn't the above breakers work just fine in the PD?
They've got ratings from 3 to 30A. These are the parts that the PD was designed to utilize in the "30A" position (refer to the following datasheet, chapter 3.2.2).
http://www.usfirst.org/uploadedFiles/3-FRC%20Control%20System-Component-Datasheets-Rev-0-5a.pdf
Russ
In a little bit of googling, I haven't found a distributor for Snap Action circuit breakers, other then AndyMark, who just started carrying the same sizes that came in the kit. I haven't called Snap Action, though.
As for the original question, the Snap Action breakers have much better trip characteristics then most fuses/circuit breakers for the application we are using them for. As for why the rules were written that way in the past, I don't know. Like Russ said, with a new control system, I think some of the electrical rules will be re-thought out.
Our Power Distribution mjgard Electrical 17 23-01-2008 15:17
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
New Power Distribution jsmith234 Electrical 6 03-02-2007 15:05
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
