Go to Post We want to be a positive force in our community, and maybe to encourage our country’s best and brightest to go to work for the ones who’ve put themselves in harm’s way. - Jack Jones [more]
Unread 02-01-2009, 15:49
Re: Power Distribution Board making noises
Originally Posted by ravena View Post
Our power distribution board started making noises. It makes both a mid level hum and a separate crackling or arcing noise. All lights are correct and everything else seems to work.
Anyone else experienced anything like this?
hum and crackling noises sound like a problem to me. Start by removing all cricuit breakers and then turn the power back on. If the hum and crackling have gone away, try installing breakers one at a time. Breakers do go bad and are known to have manufacturing defects. The crackling noise could be a bad contact in a breaker. If the hum remains with all breakers out, doulbe check your outboard voltage wiring to the camera, CRIO, and sidecars. You might have crossed connections, which is producing a short on the output of one of these independent power supplied internal to the power distro board.
5v LED on Power distribution board? Hadi379 FRC Control System 6 18-12-2008 15:59
Our Power Distribution mjgard Electrical 17 23-01-2008 15:17
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
