Go to Post RoboRIO brownout (v, n): The GDC's alternative to limiting the number of motors allowed on a robot. - GeeTwo [more]
Unread 03-01-2009, 17:28
KE5WGE's Avatar
KE5WGE KE5WGE is offline
FRC #1391
KE5WGE has a spectacular aura aboutKE5WGE has a spectacular aura aboutKE5WGE has a spectacular aura about
Rule G14
Can somebody elaborate on rule G14. I get the idea of it but I don't get it.
"Who makes the best mic pre for the money? You Do!"
Give me something to figure out and I'll break it. Give me another and I'll blow your mind.
Unread 03-01-2009, 17:34
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Rule G14
If your alliance scored 2x your opponents last match, your team will have one less ball available to the Payload Specialist. If 3x, 2 less balls. What kind of balls they are depends on which Payload position your team takes. If at the Outpost on the side of the field, then less Empty Cells. If at the Airlock on the ends of the field, then less Super Cells.
(since 2004)
Unread 03-01-2009, 17:35
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Rule G14
But you need the empty cells to be able to use the super cells so does it really matter?
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 03-01-2009, 17:36
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Rule G14
If you want to help us help you, than you could have copied it here. For the real answer look at this thread that would have shown up on a search or not seeing as it was three minutes earlier and that is not much, but you can still find your answer. http://www.chiefdelphi.com/forums/sh...804#post789804
- Arizona North
<G14> Shenanigans? Team1710 Rules/Strategy 123 12-01-2009 12:42
G14 & a difference between start & end of match Elgin Clock Rules/Strategy 6 09-01-2008 20:26
G14 - ball on rack at end ericand Rules/Strategy 5 09-01-2008 08:00
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
Rule K3? Raul Rules/Strategy 9 05-01-2003 06:38
