Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 03-01-2009, 18:03
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
Hovercraft
I know that this has crossed other teams minds and so I'm just going to throw it out there. It comes down to who can build and control it better anyway...
Rule R-06 states that we must use the wheels provided to "provide traction between the ROBOT and the ARENA." However if we throw caution to the wind and think about the idea of a hovercraft the shirt used to hover doesn't provide traction, it reduces traction. Then fans provide thrust.
This would normally make you more easily pushed but this year everyone is going to be getting pushed around (I've seem the math, with wheels alone you simply cannot get more traction). This could give you more maneuverability and better control of your bot (and with four CIM's available and a compressor I'm sure it's doable).
Is it allowed?
Would it work?
Am I crazy?
Unread 03-01-2009, 18:06
NickJames's Avatar
NickJames NickJames is offline
I'm Nick James
FRC #1989 (Viking Robotics)
NickJames is an unknown quantity at this point
Send a message via AIM to NickJames
Re: Hovercraft
Try it out and tell us how it goes. [=
Unread 03-01-2009, 18:08
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Re: Hovercraft
From what my team talked about, and this may not be right, but the way we interpreted it is that they would probably get you on the friction between skirt and the ground. It definitely seems like as far as moving components, they don't really want anything touching the ground, except manipulator parts or w/e.
Of course, I'm not authority, this would be a question for the GDC when the forums go up if you really can't find anything about it in the manual.
Unread 03-01-2009, 18:12
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Re: Hovercraft
Also you have to remember that you are dragging a trailer, that will be pulling you down, and I think that has to have wheels, which can make it for a vulnerable bot.
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 03-01-2009, 18:13
taylort taylort is offline
Lunatic! Lunatic!
AKA: Taylor Tsuboi
FRC #1293 (D5 Robotics)
Team Role: Student
taylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond reputetaylort has a reputation beyond repute
Send a message via AIM to taylort Send a message via MSN to taylort Send a message via Yahoo to taylort
Re: Hovercraft
From my point of view, at the start of the match, your skirt will be touching the ground and thus be considered as providing friction between the robot and the arena, in violation of <R06>.
Not to mention, I don't see much advantage in having a hovercraft. You're better off with rover wheels, in my opinion...you might be able to get up off the ground, butI doubt the fans you're going to use for thrust will get you very far. Granted, I've never messed with many hovercrafts, so I can't say anything on that for sure.
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Hovercraft
I think a pure hovercraft would be a silly idea. Throwing away the traction that you ARE allowed from your wheels and opting instead for an even harder to implement and control drive system doesn't seem like the right idea.
However, using a fan to augment your acceleration and deceleration might work. The wheels can only give you a maximum of about 26.7N of acceleration1 force. If you build a fan that's good for a few newtons of thrust2, then that can be a substantial increase in your robots straight-line handling, allowing you to outrun someone intent on dropping rocks in your trailer (and maybe even causing a bit of aerodynamic drag against them).
1: Maximum mass of robot: 54.54kg. Weight = 54.54 * 9.81 = 535N. Maximum traction: ff = uFn -> ff = 0.05 * 535N = 26.7N
2I know nothing about fans. This may very well be outside of the possibilities for a 12V fan, but it would be worth running numbers on.
Unread 03-01-2009, 18:18
dtengineering's Avatar
AKA: Jason Brett
Re: Hovercraft
Originally Posted by smartkid View Post
O.k. Our team has a policy where we keep our ideas to ourselves however I know that this has crossed other teams minds and so I'm just going to throw it out there. It comes down to who can build and control it better anyway...
Is it allowed?
Would it work?
Am I crazy?
First of all, crazy is relative. For instance, for the next six weeks my relatives think I'm crazy.
It could, possibly, work. I figure that with wheels your maximum pushing force will be about 9 lbs (150x.06). More, of course, when you're on the carpet at the edge of the playing field, which may become a factor.
With proper gearing and blades, it would be possible to generate at least a few pounds of thrust using the CIMs. The catch, of course, is that you will have to put a serious safety cage around your propellors.
You will also have to have your motors running at pretty much full blast the whole time you are playing, and will actively have to stop your robot, rather than just relying on wheel friction to bring it to a stop.
So while a hoverbot would be extremely cool, I suspect it would offer more disadvantages than advantages.
But perhaps, if you take the hovercraft idea and run it in reverse, you might come up with an idea to give you an edge. Let's just say... what if your hovercraft.... sucks?
Jason
P.S. R06 states that "robots MUST use rover wheels to provide traction", so perhaps the hoverbots aren't allowed unless they have a token roverwheel touching the ground at all times.
Unread 03-01-2009, 18:23
smartkid's Avatar
Boom!
AKA: Cody Smith
Re: Hovercraft
I personally also brought that idea to the table, before the idea of a hovercraft. But after reading R06 a few times a vacuum under the bot would be considered a "traction device" would it not?
Unread 03-01-2009, 18:25
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Hovercraft
This is a question that should be posed to FIRST, and I hope they vote in the affirmative that you can make a hovercraft.
And to pose the question as to if we can suction ourselves to the floor is another good question.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 03-01-2009, 18:38
Bongle's Avatar
Re: Hovercraft
To continue this train of thought and get an idea of what would be possible. Note that neither of these would be legal:
A $2600USD model aircraft jet engine puts out 59N: http://www.trimair.com.au/index2.html. However, it is petrol powered and obviously illegal.
A $740 set of ducted fan components can put out 13-15lbs of thrust (57.9N), but uses a minimum of 3200 watts, which is 6.6 times how much power a FIRST robot can use.
Unread 03-01-2009, 18:41
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Re: Hovercraft
You could put free rolling wheels under the skirt so that on start-up, the skirt lifts the robot off the wheels. Also you could use several of those silver motors to power a centrifugal fan similar to this one. They are commonly used in commercial hovercraft and are more efficient at this task than a vacuum or a typical fan partially because it disperses the air evenly. Then use 2 cim's per fan for propulsion in a dual rear fan set-up.
Here's the type of fan I'm talking about.
Can you play Crysis?
Unread 03-01-2009, 18:44
AKA: Jason Brett
Re: Hovercraft
I'd tend to think of it as a "normal force increasing device". Technically the vacuum would not provide any traction... it would merely increase the force acting on the wheels allowing them to provide enhanced traction.
I believe the Q&A needs to answer this one, though,
Jason
Unread 03-01-2009, 18:48
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Hovercraft
F1 buffs will get this one.
EDIT: Hmm, where did the picture go? Err, anyway...
en.wikipedia.org/wiki/Brabham_BT46B
Does anyone else remember when TBA signatures actually worked?
Unread 03-01-2009, 19:02
smartkid's Avatar
Boom!
AKA: Cody Smith
Re: Hovercraft
I like that logic. Let me ask, to get a good vacuum would you need to touch the surface of the playing field or would you be able to make a duct that comes very close to the surface but does not touch?
Unread 03-01-2009, 19:08
Racer26 Racer26 is offline
Re: Hovercraft
I would think touching the surface would be required to gain significant benefit from it, however, it might just be a use for all those banebots/FP motors my team never finds a use for, if the Q/A determines its allowed (which i think is unlikely)
pic: Hovercraft cart ChristinaR Extra Discussion 41 09-04-2008 02:24
Hovercraft? jennpeeler Rules/Strategy 19 25-10-2006 19:46
Hovercraft edomus General Forum 24 02-06-2005 21:00
pic: Hovercraft edomus Extra Discussion 11 01-06-2005 11:55
